Old 07-12-2015, 01:10 PM   #1
52flatheadf1
52flatheadf1's Avatar
Default Dual temp guages
Hello all, I have a 52 ford f1 239 and I am looking to install 2 6volt water temp aftermarket guages to monitor temp on both sides. Has anyone done this that can share where they ordered parts? Thanks!
52flatheadf1 is offline   Reply With Quote
Old 07-12-2015, 01:13 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Dual temp guages
Just change the overheatswitch out for a temp sender and have a 2 way rocker switch to change between right and left side using your original instrument.
Old 07-12-2015, 01:14 PM   #3
52flatheadf1
Wow, what an excellent idea! Never thought of this...
Old 07-12-2015, 10:38 PM   #4
47 flatbed
47 flatbed's Avatar
I used a single pole double throw on mine with factory sending units and ran a wire to each unit then to switch and set the switch for left throw for left head and right throw for right head. Switch was just a couple of dollars and fit in the hole under dash already there.
47 flatbed is offline   Reply With Quote
Old 07-12-2015, 11:33 PM   #5
Old Henry
Old Henry's Avatar
Here's how I installed a mechanical gauge on my 59A. I think it would work the same on yours and two can be installed for each side for twice the price as one.
Can you find my second gauge in my dashboard?
Here it is:
I didn't want it distracting from the authenticity of my dash board so I put it in the glove box to be able to check it when I want to or just leave the glove box open if it's at a critical temperature and I want to watch it. Otherwise, it's out of site.
Installation was less than 30 minutes. Only hole I needed to cut was in the back of the glove box. Sensor passed through my steering column hole with ease.
And ran right up to the left side sender port.
Gauge cost $17.95 at AutoZone.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 07-13-2015, 08:06 AM   #6
Johnnydidd
Johnnydidd's Avatar
Use mech gauges, they are more accurate and the calibration is spread over a larger aera
Johnnydidd is offline   Reply With Quote
Old 07-13-2015, 09:29 AM   #7
41Joe
41Joe's Avatar
I installed two mechanical gauges under the dash. One on each side of the wheel. Worked for me at least. But I do like the toggle switch idea so you don't have to add extra gauges.
41Joe is offline   Reply With Quote
Old 07-13-2015, 02:02 PM   #8
john worden
john worden's Avatar
My Lincoln has twin heat gauges (as well as a trans. oil temp gauge) . I like to know at a glance what the temp is. But then I like gauges.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 07-13-2015, 02:08 PM   #9
Steves46
Steves46's Avatar
Nothing additional to the topic but would like to say I like your truck. What does the door art read? Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 07-13-2015, 04:03 PM   #10
flathead 53
I use the original electrical temp gage, and a mechanical on the other side the mech gage gives you actual degrees of temp,this is on my 40 coupe
flathead 53 is offline   Reply With Quote
Old 07-13-2015, 04:43 PM   #11
Roger/Sacramento
Roger/Sacramento's Avatar
I did this on my '41 pickukp
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 11-11-2015, 11:07 AM   #12
41Joe
41Joe's Avatar
I know this is an older thread, but I just saw this product and thought it was cool.
http://www.genosgarage.com/product/w...-black/westach
It's not cheap, but what is?
Old 11-11-2015, 11:25 AM   #13
PeterC
PeterC's Avatar
I used dual mechanical to monitor side by side simultaneously - see pic - the two on the left of the cluster
PeterC is offline   Reply With Quote
Old 11-11-2015, 11:34 AM   #14
brentphx
Westach says that they do have a 12v 2" dual water temp gauge- 2DC3-7 100-260F. It's $121 plus the two senders at $35 ea. compared to generic autometer gauges at $60 ea x2 that come with senders.... $70 to have it on one dial... decisions decisions. At least there is an option! Here's a pic
brentphx is offline   Reply With Quote
Old 11-11-2015, 12:37 PM   #15
s nichols
s nichols's Avatar
I have 2 mechanical gauges on my AV8 mounted under stock dash
s nichols is offline   Reply With Quote
Old 11-11-2015, 01:04 PM   #16
George49Ford
George49Ford's Avatar
Two mechanical gauges on mine (available at NAPA). Work very well.
George49Ford is offline   Reply With Quote
Old 11-11-2015, 01:05 PM   #17
RalphM
RalphM's Avatar
Neat looking gage! But by the time I figured out the conversion to Fahrenheit it would over heat on me
RalphM is offline   Reply With Quote
Old 11-11-2015, 01:10 PM   #18
flatheadmurre
Dual gauges like that is common in aircrafts.
All kinda combos available.
Old 11-11-2015, 03:20 PM   #19
brentphx
Exactly why I emailed them asking about a model showing F. I was worried about the scale. They gave me the model I listed, since I don't need the high end of the temp scale on a flathead. I linked that pic since they didn't have the F model on their site (even though they make them).
