can anyone tell me the difference (if there is a difference) between a f1 and a f100 steering box. thax Lee
have the same question. this might help. what do i have here, f1 or f100?
F-100 it's not a F-1
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
When is position, the F1 worm is BELOW the pitman shaft, the F100 is ABOVE the pitman shaft. Here is a shot of the F1 box (with modified flange) in my 32 Sedan. Note the worm is underslung - ie below the pitman shaft. You will also note the stock 32 pitman arm fits the F1 box. ![]() The F100 box has a bigger shaft and the pitman arm has a clamp bolt. Mart. Edit: I see the filler plug location is slightly different. From this I would say the box shown is not F100 for sure, but is similar to my F1 box. From the orientation of the bolts, it may have been made for a 33/34 rather than a 32. Last edited by Mart; 11-14-2010 at 05:56 AM. |
| Thread Tools | |
| Display Modes | |
