Old 06-28-2015, 11:15 AM   #1
ricklove
ricklove's Avatar
Default Wing Window ?? - 1948 Tudor Sedan
The passenger side wing window (vent window??) has a 1/32" (??) gap along the entire edge where it's supposed to be snug against the upright. Any ideas how to adjust it (or rubber trim) so that it doesn't leak air AND water? TIA!
ricklove is offline   Reply With Quote
Old 06-28-2015, 11:59 AM   #2
1942deluxe
1942deluxe's Avatar
Default Re: Wing Window ?? - 1948 Tudor Sedan
Are you talking about where it meets the weatherstrip on the division bar? You may be able to pull the glass straight back where it will seal.
Old 06-28-2015, 12:23 PM   #3
J Franklin
J Franklin's Avatar
If you can't adjust the glass it would be fairly inexpensive to replace with a piece that will fit. Maybe someone replaced it from a wrong model at the junk yard. Is it the same size as the drivers side (glass & opening)?
Old 06-28-2015, 01:44 PM   #4
B-O-B
B-O-B's Avatar
Believe it has a rubber molding strip & a piece may be missing. Bob Drake catalog #29 page 580 & see if that is what you need.
B-O-B is offline   Reply With Quote
Old 06-28-2015, 02:19 PM   #5
48 coupe
48 coupe's Avatar
My 48has the same problem. I put new rubber seals or[ what ever there called.] When I did the restoration . The seals were very hard . liked to never get them installed. I guess they will just stay that way. Just like the door handles that sag.
48 coupe is offline   Reply With Quote
Old 06-28-2015, 05:09 PM   #6
waterboychuck
waterboychuck's Avatar
It does sound like you have a piece of glass that is not original. Does it have the Ford bug on the glass? If not you can order a replacement, with or without bug, from https://www.sandersreproglass.com/orderonline.php
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 06-28-2015, 10:20 PM   #7
Drbrown
Drbrown's Avatar
48 COUPE: Door handle sag .... switch your two door handles .... left for right.
Drbrown is offline   Reply With Quote
Old 06-28-2015, 10:47 PM   #8
fordor41
fordor41's Avatar
does the vent window close completely and lock? if not I had to trim the rubber gasket with a razor blade, on my '41. Checked where frame touched the gasket and shaved material slightly until the window closed completely and locked
fordor41 is offline   Reply With Quote
Old 06-29-2015, 01:09 AM   #9
Graeme / New Zealand
Graeme / New Zealand's Avatar
Take it from a 48 owner it is either the glass is too small or it is poorly adjusted in the frame or the upright bar is wrongly positioned .You might be able to get some adjustment by removing the interior door panel loosening off the bolts that hold the upright division in place and the small screw at the top of the division bar and sliding it across, if that adjustment has not already been taken up.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 06-30-2015, 09:42 AM   #10
ricklove
ricklove's Avatar
Many thanks for all the info!!!!!!
Old 06-30-2015, 02:20 PM   #11
supereal
supereal's Avatar
Sagging door handles are almost always caused by weak, broken, or incorrect springs in the latch body, or badly worn latch hole for the handle shank. check the square handle shank for wear. we build them up with the welder and than grind and file back to the correct dimension.
supereal is offline   Reply With Quote
Old 06-30-2015, 02:51 PM   #12
4dFord/SC
4dFord/SC's Avatar
A poor man's fix for sagging door handles is a garden hose washer.
4dFord/SC is offline   Reply With Quote
Old 06-30-2015, 06:07 PM   #13
waterboychuck
I read on this site about heating the door handle and then twisting it so when put back in it is straight.
Old 06-30-2015, 06:44 PM   #14
4dFord/SC
4dFord/SC's Avatar
I was able to straighten mine in a vise without heating.
Old 07-01-2015, 12:50 AM   #15
Yep me too.
GB
