Old 06-22-2015, 05:39 PM   #1
amishboy
amishboy's Avatar
Default Foot starter smoking and sparking
I have a 36 ford darley model 51. I am having an issue with my starter pedal smoking when I engage it. I have had it off and on a few times fiddled with it but it doesn't seem like something that should be taken apart I don't know for sure this is all just new to me. I realize that smoking and sparking probably means that it is arcing I just don't understand how or why.
amishboy is offline   Reply With Quote
Old 06-22-2015, 05:51 PM   #2
48 coupe
48 coupe's Avatar
Default Re: Foot starter smoking and sparking
All electrical equipment runs on smoke. when all the smoke comes out of them they don't work anymore. That's what the big boys told me.
48 coupe is offline   Reply With Quote
Old 06-22-2015, 06:03 PM   #3
amishboy
amishboy's Avatar
That really doesn't help any but your not the first person i've heard that from.
Old 06-22-2015, 06:18 PM   #4
48 coupe
48 coupe's Avatar
Your right . I just had to go there. I would check the big wire to the starter . make sure its tight and not corroded. Feel for something hot I don't know how that old floor starter is connected . sorry for the smart ass answer.
Old 06-22-2015, 06:18 PM   #5
Capt Kirk
Capt Kirk's Avatar
My guess is bad contacts. I have no idea what this switch looks like but more than likely it's not a serviceable item.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 06-22-2015, 07:03 PM   #6
koates
More than likely the insulator fibre washers inside the foot starter switch housing are burnt, cracked, loose and the copper contact studs are shorting to ground. These switches can sometimes be dismantled and repaired if you have some insulator washers and the contacts can be filed flat again. Failing that these switches are available new from various vendors such as Macs or Bob Drake or on ebay. Just Google 1936 Ford starter switch and see what you can find. Regards, Kevin.
koates is offline   Reply With Quote
Old 06-22-2015, 07:09 PM   #7
Bob C
If it looks like this switch it looks like you can take it apart.
You can also replace your lost smoke.
Bob
Bob C is online now   Reply With Quote
Old 06-22-2015, 07:58 PM   #8
Capt Kirk
Capt Kirk's Avatar
I'd be interested in a jar of replacement sparks...Think I'll need a couple gallons to get my old high school car running again.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Old 06-22-2015, 09:52 PM   #9
ford38v8
ford38v8's Avatar
That Lucas smoke is the best that money can buy. Be careful with that stuff, it's hard to get now.
Alan
Old 06-22-2015, 10:41 PM   #10
Scott H in Wheaton
Scott H in Wheaton's Avatar
Are you moving the switch against a metal ground when you stomp on it?
Scott H in Wheaton is offline   Reply With Quote
Old 06-23-2015, 07:48 AM   #11
amishboy
amishboy's Avatar
No right now I have the floor board removed so its not touching anything at all. Its not like the one Bob posted a picture of exactly. It does bolt to the steering column and has the two lugs on the bottom. It has a shaft with a spring on it that is probably about 6 -8 inches long with a round pedal on top that comes through the floor board. I'll have to get pictures.
Old 06-23-2015, 10:57 AM   #12
Rowdy
I was on break at work when I read this thread last night. I found it interesting that just prior to break we had towed one of out fork trucks back to the shop as someone let the smoke out of the drive motor. Luckily we had a rebuilt drive motor with new smoke in inventory and had it changed before we got off work at 4 am. Maintaining 164 electric forklifts it seems we deal with smoke once in awhile. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 06-23-2015, 12:00 PM   #13
amishboy
amishboy's Avatar
Here are some pictures.
Old 06-23-2015, 12:02 PM   #14
amishboy
amishboy's Avatar
Few more.
Old 06-23-2015, 12:17 PM   #15
Bruce Lancaster
Carefully bend back the tabs and see what's going on in there!
Old 06-23-2015, 12:35 PM   #16
amishboy
amishboy's Avatar
I see what was causing the issue now but I'm not going to pretend I can fix it without some new parts. The copper piece is suppose to set in a square on the pedal side of the starter. Looks to have melted away what ever was holding it there.. It seems very possible to put the smoke back in this though.
Old 06-23-2015, 12:44 PM   #17
Bob C
Looks like a 34 switch, here's one on epay.
http://www.ebay.com/itm/1932-34-Ford...e44234&vxp=mtr
Bob
Old 06-23-2015, 12:53 PM   #18
amishboy
amishboy's Avatar
I can fix this one but there is a black square part picture above has lost its seat for the copper square to seat on. looks like it came out of its seat and the melted a snap ring that was holding it all together which has led me to all these issues.
Old 06-23-2015, 02:26 PM   #19
funrunr
funrunr's Avatar
Don't know where in Michigan you are located, I'm in Belleville and have an NOS foot starter button. It don't look like yours, looks more like a headlight dimmer switch. I would have to dig and search for it. If your willing to pick it up you can have it. Let me know and I will find it and send you pics. [email protected]
Mark
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 06-23-2015, 02:40 PM   #20
amishboy
amishboy's Avatar
Mark I appreciate the offer. I talked to the local flathead guru and he says he possibly has nos parts available Im going to check with him tomorrow.
