06-20-2015, 04:38 PM | #1 |
four row radiator for 1930?
Are there any 4 row radiators available for '30-1 cars?
06-20-2015, 05:43 PM | #2 |
Re: four row radiator for 1930?
Berg's, Walker, Brassworks could probably make one for you. Also contact Bratton's or Snyders and ask.
A good old time radiator shop could probably put a 4 row core in yours. Why?? Paul in CT |
06-20-2015, 05:53 PM | #3 |
4 row is typically for a AA truck and the radiator shell is deeper to accommodate the extra depth. A common Model A passenger car or pickup should cool just fine with the standard 3 row core.
If 3 row core ain't getting it done, your issue is probably a clogged block or restricted tubes in the existing 3 row radiator core. This might call for removing the upper and lower tanks and rodding the tubes. A can of radiator flush won't do the trick. |
06-20-2015, 06:04 PM | #4 |
Just looking for something to keep my tudor with A/C and OD cool when touring at speed in the southern states including Texas. I'm considering a Berg's 3 tube but wondering about 4 tubes that might fit if any are available.
06-20-2015, 06:54 PM | #5 |
Talk to Steve Becker at Bert's Model A. If I am not mistaken their recored heavy duty radiators are 4 rows. Reasonably priced by comparison.
06-20-2015, 10:15 PM | #6 |
I have tried to have 28/29 radiators re-cored to 4 row but so far none of them have had tanks that would carry the extra row.
I noticed the harder I work the luckier I get! |
06-21-2015, 12:18 AM | #7 |
If you want the best cooling capacity, get a VT modern core. They cool significantly better than the flat fin cores. They aren't right, but most people won't know. I have a 3 row VT core in my town sedan with AC, Overdrive & hopped up motor. It runs 175* in the middle of summer pulling a trailer. You won't regret the modern core.
Cowtown A's |
06-21-2015, 07:25 PM | #8 |
Jordan,what is a VT modern core? I haven't found a definition for that. My car is for sure a driver.
06-21-2015, 07:32 PM | #9 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
06-22-2015, 01:42 PM | #10 |
Thanks all.
