Old 06-17-2015, 02:35 PM   #41
Greg Jones
Greg Jones's Avatar
Default Re: Basket case, what do I look for? New to the hobby.
Heck for $3500 if you don't buy it I will.
Greg Jones is offline   Reply With Quote
Old 06-17-2015, 04:42 PM   #42
Kalstar
Ok look for the steel roof bows, Anything else that are hard to find on these "Steel Tops" I should keep an eye out for (or any pick up of this era for that matter)? I was told it was a late 31 truck, it has the standard bed though. Does it make it many more special to be a late opposed to an early truck 31?
Kalstar is offline   Reply With Quote
Old 06-17-2015, 05:29 PM   #43
CarlG
CarlG's Avatar
The "Late '31" pickups could come in several configurations:
• Hard (steel) top or soft top
• Indented or flat firewall
• Wide bed or standard narrow bed
Ford had a habit of using up what was in the pipeline when changes were introduced, therefore, a "Late '31" could have any combination of the 3 elements above.
Throw into that the 80+ years of constant change by the many owners of these beasts, and you really don't know what you may or may not have.
My Pickup has an Indented firewall, Hard (steel) top, and a Narrow bed.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-17-2015, 05:58 PM   #44
Jim Mason
Jim Mason's Avatar
If it is your first A, I'd recommend a complete car you can drive and learn. then consider a basket case.
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 06-17-2015, 05:58 PM   #45
1930artdeco
1930artdeco's Avatar
Hi Jim,
Here is my two cents worth. Both camps are correct you should buy one that is running and enjoy it,never to know it,need what makes them tick. You should also buy that one-especially for 3500-IF:
A) you have space
B) you have the mechanical skills. They are not complex but they do have their quirks
C) most importantly you have the time and drive. It looks like you just have the body to do from the pics. The mechanical stuff can be gone through relatively easily and quickly since the body is off.
Those are the two sides of the coin. If you opt to get it buy some pizza and root beer and have the local club come over to give you a hand. The truck will be together inside six months. Pizza and beer will cut it down to two months😀.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-17-2015, 11:45 PM   #46
Dave Mellor NJ
The extra doors are valuable.
Dave Mellor NJ is offline   Reply With Quote
Old 06-18-2015, 03:13 AM   #47
WRA
WRA's Avatar
Buy a complete and rust free car. Best advice I can give after 35 years of building and tinkering. You will be a lot of money ahead in the long run.
The pictured truck looks good for the right guy, but I would consider it a parts car. For me, it's worth the $3500 mentioned.
WRA is offline   Reply With Quote
Old 06-18-2015, 06:41 AM   #48
Kalstar
I hear you load and clear, my motivation is a little different though. I like to tinker.....someone else's restored car will never feel like mine. Even if this truck is not "the one" I would want to buy something that I could work on and make my own. I hear all the advise and maybe I should buy a completed car, drive it for a bit then decide if this project is right for me (I'll still buy the truck now but store it away). The other side of my brain is saying, "awe you can do it, just jump in feet first". I have built (3) component cars that have all been top show winners. Either way I go, I will be joining your ranks and look forward to learning.
Old 06-18-2015, 07:41 AM   #49
frank mcdaniels
frank mcdaniels's Avatar
Kalstar, Congratulations on your decision.All my cars were bought as basket cases. The thing was I didn't have the money to buy a complete finished car. I may have spent more in the long run but it was affordable in the begining and I was able to spend money on restoration as I could afford it. I would of never been able to buy the cars I have if they were already restored. It seems most people today want to take the easy way out and have everything done for them. Restoring a model A is not rocket science . Get help when you need it and try to do atleast one thing everyday on your project and before long you will have something you can be proud of and say "I did this myself". I wasn't going to comment on this thread but I just finally had to. Good luck and full steam ahead. Frank
frank mcdaniels is offline   Reply With Quote
Old 06-18-2015, 08:49 AM   #50
Kalstar
Thank you Frank for the advise.
Old 06-18-2015, 09:43 AM   #51
Tom Wesenberg
Tom Wesenberg's Avatar
Ditto what Frank said.
Buy some good Model A books and join a club and the job will be much easier.
Old 06-19-2015, 07:40 AM   #52
Jacksonlll
Jacksonlll's Avatar
Kalstar, this video may give you a few pointers. jack
https://www.youtube.com/watch?v=8xkAZil2b78
Old 06-19-2015, 04:32 PM   #53
pgerhardt
pgerhardt's Avatar
The other thing to keep in mind is that buying a "restored" car is no guarantee that it was done right. I am into my sixth month of re-restoring my 29 tudor. Looks good doesn't it? (see avatar) I thought so, but on closer inspection I have found much that was done not well, so I am going through the car again. It will be correct when I am done!
Your winning awards for your component cars shows that you have the needed attention to detail for the task. Take your time and do your research and I am sure your truck will be winning award one day.
pgerhardt is offline   Reply With Quote
Old 04-28-2016, 08:43 PM   #54
Kalstar
Well just an update, I purchased the truck last June and it has been stored away till a few weeks ago. I have started tinkering with it and hope to be driving it before Summer's end. Though it does not fit here, I also purchased a glass T-Bucket to play with in the mean time.
Old 04-28-2016, 08:58 PM   #55
Dennis Pereira
Dennis Pereira's Avatar
I'm glad you rescued that old truck have fun .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 04-28-2016, 11:24 PM   #56
ian Simpson
Kalstar, just buy it. My wife and I bought all three of our collector cars without even sitting in them, let alone crawling underneath or driving them. I know we are not typical, but we do not expect to make money or even re-coop our investment. Any loss or profit will affect the value of our estate, not our standard of living. The day by day cost of maintaining and improving the cars is just the cost of having fun.
Keep us posted on the rebuild, I am envious but the time for my undertaking such a task is long gone. But I did have the pleasure of undertaking three frame-off restorations of more modern vehicles over the past several years.
ian Simpson is offline   Reply With Quote
Old 04-28-2016, 11:31 PM   #57
Tom Wesenberg
I agree with Ian. I enjoy antiques cars for the fun, and not for a profit.
Old 04-29-2016, 05:10 AM   #58
Kalstar
Thx Dennis Ian and Tom, I intend to enjoy the rebuild as much as the end product. I too could careless if this is for profit or loss undertaking. Though looking at eBay, it seems clean model A prices have risen in recent years.
Old 04-29-2016, 06:55 AM   #59
Domino
Domino's Avatar
Send a message via AIM to Domino
Overall it looks pretty good - certainly not a basket case and could be a bargain. Making sure it is complete is important. One item that is frequently forgotten is the radiator. In that they cost 550 - 800 to replace make sure it is usable.
A good price is one that you both find acceptable. It's value to me would be $3,000 to
$4.500. But prices vary regionally. If you are a large person, you might find a local one and sit in it. Two of my friends found the fit in the pick-ups they purchased was too tight.
Domino is offline   Reply With Quote
Old 04-29-2016, 07:41 AM   #60
cradlescyth
cradlescyth's Avatar
buy it !!!
cradlescyth is offline   Reply With Quote
