Looking for quality Non detergent Motor oil in grades sae 30 and 40
I am using Valvoline sae 30 but think I should be using sae 40? It seems that Non-detergent oil is sold by unusually producers. Anyone ever use Amalie Oil?? Any suggestions. Last edited by FrankWest; 05-18-2015 at 08:51 AM. |
Non det. hard to find in my area. Just go to a 90 wt. gear oil. I think that is about 50 wt. oil.
Why do you think that you need to use non-detergent oil?
I wouldn't use AMALIE on a squeaky door hinge. First-hand experience many years ago..........baaaaaaaaaaad! DD
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Tractor Supply has it
I have an original engine car. The car was stored for 20 years without running.
When I purchased the car, I dropped the oil pan and it was not bad.. about and inch of sediment..that was like sand..not greasy sludge. I was told that that type of pan deposit is a result of running non-detergent oil. I got the car running and added a quart of MMO. Now I want to begin frequent oil changes to clean the engine. Are you telling me that most of you guys running 80 year old engines use regular bargan basement motor oil? I'm so confused. |
The "detergent" in the oil is actually additives to combat the contaminants from the combustion chamber that leak past the rings and moisture. If you have already cleaned the pan, use any modern oil that you would consider a "detergent" oil. I wouldn't use "non detergent" in a lawn mower.
#10 | |
As long as you have de-sludged it, any reasonably good modern oil will be ok.
Anything from the supermarket cheapie to the most expensive one you can find will all work ok. Old engines tend to leak more than modern engines, I use that to support my likeness for oil from the cheaper end of the price scale. Plus I'm tight. Mart. |
#12 | |
Don't know what "bargain basement oil" is?
#13 |
In the olden days it was fairly common to clean out an engine by running it on a kerosene and light weight oil mixture for a short time. Then drain it out and use regular oil.
#14 |
Not a 4 banger but I do run 10/40 detergent oil in it. Most times I get my oil from wal-mart. They seem to have the most reasonable prices. On occasion the parts stores will run a promotion ad & I will stock up then.
#15 |
Here we go again.
DO NOT use hypoid gear lube in a crankcase just because the viscosity may be of a similar grade to what you want to use. The extreme pressure additive contains sulfur/phosphorus which will dine on your main and rod bearings. It is true that piston type compressor oils typically don't contain detergents, and can be had in correct viscosity grades for a motor vehicle, however they are often made from naphthenic base stocks that are less thermally stable than the parafinic base stocks that every non-synthetic crankcase oil is made from. Crankcase oil detergent/dispersants don't act like an often advertised bathroom cleaner.......they are not "scrubbing bubbles". Their primary action is to suspend contaminants (mostly by-products of combustion as correctly noted by deuce roadster). Most dislodging of built up deposits comes from fluid movement. Putting a "quart" of MMO in an engine would probably cause much more "detergent" like action than regular motor oil since it contains a solvent.
Luck occurs when preparation and opportunity converge. Last edited by Uncle Bob; 05-18-2015 at 11:12 AM. |
#16 |
Old Ford flathead oil is a lot like Chicago politics.
"Vote early and vote often" "doesn't matter who you pick, its always the same old BS" so change your oil often, and because these old engines have fairly loose tolerences and run kind of dirty they will work fine on just about any type of clean oil...detergent/non-detergent. single viscosity vs multi-viscosity, 30w vs 50w |
#17 |
#18 |
Sorry for bringing it up.
Now I remember the big argument about oils. I was not asking, if I should use non-detergent. I was asking where to get it. I know there are many positions on what to use. One guy even recommended to use synthetics in his model A. I just do not want to KILL my engine by using the wrong stuff. That's all. One guy said something last time that really scarred me. He use a special detergent oil to clean his engine and it clogged the engine up. When he removed the pan..he found something that looked like black corn flakes and the oil pump screen was also clogged. |
#19 |
Even modern "bargin basement oil" is better than the best oil available back in the 30s and 40s.
#20 |
This is 2015 not 1915 Things change in the oil world.
| Thread Tools | |
| Display Modes | |
