Old 05-17-2015, 06:00 PM   #1
skidmarks
skidmarks's Avatar
Default Re: 8ba, getting the cam out
do you have to switch to the early timing gears when putting a early cam in a 8BA block ? I think the pitch changes the direction of the thrust
skidmarks is offline   Reply With Quote
Old 05-17-2015, 06:41 PM   #2
Tony, NY
Do you have adjustable lifters? Wouldn't the valves have to be adjusted to the new cam?
Tony, NY is offline   Reply With Quote
Old 05-17-2015, 07:05 PM   #3
oldford2
oldford2's Avatar
If you change the cam to earlier you will also have to change to early timing gears and cover. No big deal there. I believe either Walt Dupont or OlRon posted how to hold the valves up to remove the cam. Maybe they will chime in.
John
oldford2 is offline   Reply With Quote
