Old 01-03-2015, 01:18 AM   #1
Kpar
Kpar's Avatar
Default Gas Gauge Thread
Can somebody tell me what the thread is on the brass hex tube at the back of the fuel gauge. I purchased a gas gauge line kit but the nuts supplied seem to have a different thread. Also is there different sizes for the copper tubing ?. The one on my 33 is 1/8" OD, the kit I bought is a lot smaller.
Kpar is offline   Reply With Quote
Old 01-03-2015, 01:45 AM   #2
Brian
Brian's Avatar
Default Re: Gas Gauge Thread
5/16"x28 TPI
Old 01-03-2015, 04:20 AM   #3
koates
Hi there. If the OD of your fuel gauge capillary copper tube is 1/8" (.125") then it is too large and not correct for the application. My original 1934 ford fuel gauge air line is .099" OD. The replacement reproduction copper air lines are approx. .085" OD. You should be using that one. So Im not sure what size air line nut you are trying to fit onto the gauge unit male thread. The air line kit fittings should fit correctly. The original air line tubing was permanently attached (soldered or braised) to the fuel line and supplied as a single part. This air line tube has to be absolutely air tight from the gauge to the tank sender to work correctly and therefore all your line fittings must fit perfectly. No rough jobs, incorrect fittings or sealing tape etc allowed here. Regards. Kevin.
koates is offline   Reply With Quote
Old 01-03-2015, 06:44 AM   #4
Terry,OH
Terry,OH's Avatar
When the nut is tightened down on the fitting it seems to distort the first few threads on the hex tube. Makes them bulge slightly, you can usually get the new nut to start, by hand.
Old 01-03-2015, 08:51 AM   #5
G.M.
The OD of the tube is not important, the ID is. G.M.
www.fordcollector.com
Old 01-03-2015, 11:02 AM   #6
B-O-B
B-O-B's Avatar
You might want to be careful on tightening the nuts on those old brass fittings as they can be brittle & snap pretty easily.
B-O-B is offline   Reply With Quote
Old 01-03-2015, 07:47 PM   #7
Kpar
Kpar's Avatar
Originally Posted by Brian View Post
5/16"x28 TPI
Thanks Brian, I did use a thread gauge to check but I think it has been stressed by over tightening in the past.
Also thanks to all other responses on correct sizes.
Old 01-03-2015, 08:01 PM   #8
deuce_roadster
deuce_roadster's Avatar
The correct small air lines I have seen have very small tapered ends that you need to solder on AFTER slipping the nut over the end of the line.
Old 05-12-2015, 07:31 PM   #9
morrisgauge
On the hydrostatic gauges, we find it beneficial to service the gauge and follow the calibration procedure outlined here:
morrisgauge is offline   Reply With Quote
Old 06-16-2015, 09:05 PM   #10
wingerdinger
wingerdinger's Avatar
Thank you, Morrisgauge, for the document. I have been looking for something like that for a while.
My tank unit is in fair condition after soaking and cleaning, except that the air chamber is full of holes. I am going to attempt to solder or braze it.
wingerdinger is offline   Reply With Quote
Old 08-22-2024, 07:06 PM   #11
Neal Beck
can anyone tell where or if the parts for my 34 ford hydrostatic gas gauge are available? everywhere i look says they are out of stock.
Neal Beck is offline   Reply With Quote
Old 08-23-2024, 02:51 AM   #12
deuce lover
deuce lover's Avatar
Renner's Corner in MI or straight-eight.com .
