OK, got the thermostats from Federated Auto Parts with a part # 419-180 made in Israel. Problem now to seal. Tightened clamps quite well and added liquid back and leaked like crazy. Was hoping it would seal around the little wires without gasket shellac or some thing that would be a "bear" to pull apart later on if needed. What all you guys using ?
#2 | |
Also, if you're using the wires as I illustrated, they have to be a very thin strand pulled from a piece of small gauge stranded wire for the hose to seal around them.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 04-25-2015 at 05:22 PM. |
| Thread Tools | |
| Display Modes | |
