Old 03-21-2015, 10:26 PM   #1
gearhead1952
gearhead1952's Avatar
Default Re: F1 Radiator Fan Shroud
Probably easier to put a v8 shroud on a 6 than the other way around. The v8 radiator has 4 hose connections and the six only has two. The v8 shroud is dimpled at the bottom for the two hoses. Not sure if the fans are located in the same spot between the two engines. There is a v8 shroud on ebay now although a bit pricey.
http://www.ebay.com/itm/1948-1949-19...-/121601304838
gearhead1952 is offline   Reply With Quote
