Old 03-04-2015, 05:36 PM   #1
PO51
PO51's Avatar
Default Adjustable seat
Could someone tell me which 30/31 models had an adjustable front seat? Does having it give you anymore leg room?
PO51 is offline   Reply With Quote
Old 03-04-2015, 05:38 PM   #2
Tiny
Tiny's Avatar
Default Re: Adjustable seat
My coupe has an adjustment knob. Being 6'1" I keep it all the way back. I think coupes are the roomiest in the front seat and 28-29 RPU's are the smallest.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 03-04-2015, 05:50 PM   #3
Jwilli
Jwilli's Avatar
My 30 murray fordor has the adjustment. I am only 5' 10" and I have to keep it all the way back. It only moves about 4 inches.
Jwilli is offline   Reply With Quote
Old 03-04-2015, 06:42 PM   #4
PO51
PO51's Avatar
Thanks for the info, I'm 6'3" and finding that after hip replacement driving my 28 RPU is next to impossible. With a 36" inseam I trying to figure out what model would best, my 29 Business Coupe is only good for short trips, anybody had any luck with removing the package tray in a 28/29 and moving the seat back?
Old 03-04-2015, 08:48 PM   #5
glenn in camino
glenn in camino's Avatar
My 31 sport coupe has one. I move it forward when my wife drives it.
Old 03-04-2015, 09:08 PM   #6
Tom Elliott
I believe the 31 s/w fordor has the most leg room. That's one reason I picked one up to restore. I am 6'2, both knees and right hip replaced. Needed more room. I had a 30 coupe and that wasn't bad but getting in a s/w fordor is much better
Tom Elliott is offline   Reply With Quote
Old 03-05-2015, 10:39 AM   #7
rons49
rons49's Avatar
The Tudor Deluxe >June 1931 had a adjustable seat similar to the 1932 models. They can be added to standard Tudors. Check Brattons catalog. Also the Victorias had adjustable seats as well.
rons49 is offline   Reply With Quote
Old 03-05-2015, 11:33 AM   #8
Scott Hall
Scott Hall's Avatar
My 31 Murry sedan has an adjustable front seat that is all the way back plus a couple of inches. If you search on here you should find a thread that explains how to remove the adjusters four bolts and move the bracket so that you only use two of the bolts. I did this a couple of years ago and I couldn't be happier. You only get 2 or 3 inches but when your my size (6'4" and 270 lbs.) it feels like much more.
Scott Hall is offline   Reply With Quote
Old 08-17-2015, 11:57 AM   #9
mcadambi
Does any one have an assembly drawing showing how to install the bkt,seat adjustment bolt,seat knob and the adjuster nut in a 1931 coupe?I think I am missing the seat adjuster nut,that is why I can not get the mechanism to work.Any help wold be appreciated.I want to achieve the maximum movement.
Madhav Cadambi
mcadambi is offline   Reply With Quote
Old 08-17-2015, 12:12 PM   #10
mcadambi
Please send email with attachment to [email protected]
