Old 02-11-2015, 10:08 PM   #61
Harley03joe
Harley03joe's Avatar
Smile Re: Fuel Filter
Originally Posted by Mitch//pa View Post
thanks Joe,
see post #35 i use the wix 33039
Your Very Welcome Mitch.
I Got The Same Filters Wix 33039, I Like Them Because The Fuel From The Tank Go Thru Them First, Not Like The Org Ones Where The Fuel Goes Thru The Outside First ,I Think This Is A Better Way To Filter Fuel.
But Will The Holes On The Top Of The Wix Filter Get Block Off By The Bowl Cork Gasket ??
I Do Have A Hand Punch, Do You Think It Would Be A Good Idea>>> To Make The Holes A Little Bigger On The Inboard Side ?
Joe
Harley03joe is offline   Reply With Quote
Old 02-12-2015, 07:30 AM   #62
Mitch//pa
Default Re: Fuel Filter
Joe
Hi Joe,
no modifications or reengineering is needed
Old 02-12-2015, 08:56 AM   #63
Rocketsled
Rocketsled's Avatar
Default Re: Fuel Filter & Magnet
Has anyone put a magnet in the tank?
Rocketsled is offline   Reply With Quote
Old 02-12-2015, 10:16 AM   #64
afuncar
I placed a 4 inch speaker magnet by my gas outlet of my tank, I think it's helped keep the rust out of carb. I also placed a filter or trap from one of the parts suppliers in the sediment bowl, every little bit helps.
afuncar is offline   Reply With Quote
Old 02-12-2015, 07:45 PM   #65
daveymc29
daveymc29's Avatar
I went to my local auto parts house, not a NAPA store and asked to cross reference the NAPA 3039 filter and they came up with a WIX 33039 that works fine. It also has a gasket built onto the top of it that seals to the glass bowl just fine. The gasket has a row of small holes around the outside of it to allow fuel to enter. I asked about a small magnet for inside the bowl and the guy ripped a refrigerator magnet off his cabinet and told me "There, free, cut as many as you like," So I did cut one and have material for more if I like the outcome.
daveymc29 is offline   Reply With Quote
Old 02-12-2015, 10:07 PM   #66
Skibb
Skibb's Avatar
Originally Posted by Jack '29 Sport Coupe View Post
I was over at my friend's house the other day and watched as he installed his carburator after cleaning out the mesh micro filter that disolved as a result of todays fuels. What a mess. He told me that he was going to put
in an inline filter instead. Soooooo, I opened the rumble lid on my coupe and
pulled out my spare filter and told him to try it instead----no need for clamps, no need for hoses to splice into the fuel line, no need to cut the line, etc., etc.... A lot of guys on the barn know the filter I'm talking about, but for you newbies it's the NAPA filter P/N 3039 that sits in the glass sediment bowl. Of course it doesn't work for you guys with the sediment bulb, lol. What I like about this filter is that once it is installed
there is about an inch of space between the bottom of the filter and the
glass bowl-----plenty of room to place a small magnet to pick up any rust
particles that the filter might miss. I use a 1/4" X 1: industrial magnet that
grabs onto the bottom of the filter on the metal rim. Pretty neat. My
friend is as "happy as a clam." JMHO
Jack
Jack, excuse his dumb question. I've found some 1/4" x 1/4" x 1" magnets and some Disc magnets 3/4" x 1/16". Would the first fit or which would be yur choice.
thanks, Skibb (Home of the Rustest Tank on the Model A Highway)
Skibb is offline   Reply With Quote
Old 02-12-2015, 10:34 PM   #67
Harley03joe
Do You Have A Picture Of The Trap ???
Thanks
Harley03joe
Old 02-12-2015, 10:39 PM   #68
Harley03joe
The Best &Strongest Magnet I Ever Had Was 2 From A Computer Hard Drive
Takes Two Hand To Pull Them Apart If You Can, I Can't So I Slide Them Sideways Till They Come Apart, There Very Very Strong, I Have 2 On The Outside Of My Fuel Tank In The Cab On My 31
Old 02-12-2015, 10:45 PM   #69
Harley03joe
Hi Joe,
Ok Mitch I See The Holes, Thanks Again For The Info.
Mitch Check This Place For Filters Ok
Thanks Again
Joe
http://www.discountfleetsupply.com
Discount Fleet Supply - Heavy Duty Fleet Products - Buy Online! - www.DiscountFleetSupply.com
Old 02-12-2015, 11:26 PM   #70
Harley03joe
Hi Joe,
Mitch ? So You Don't Need The Spring ? Right
Joe
Old 02-13-2015, 06:21 AM   #71
Mitch//pa
Joe
correct no spring, the filter is held up in place by the bowl
Old 02-13-2015, 06:29 AM   #72
Mitch//pa
Thanks Again
Joe
thanks Joe,
for the link yes 2.90 is cheap but the shipping is over 10.00...
i get them from my shop jobber for 5.43 no shipping ,,no tax
Old 02-13-2015, 07:45 AM   #73
Mitch//pa
Jack has not signed on the barn since 9/8/14 @ 9:32 a/m so you might be waiting a while for your answer...
Old 02-14-2015, 01:02 AM   #74
Harley03joe
thanks Joe,
O well You Win Some A Loss The Rest Ha Ha
Thanks
Joe
Old 02-14-2015, 01:03 AM   #75
Harley03joe
Ok Thank You Mitch
Joe
