Old 12-11-2014, 08:03 PM   #101
dustyp489
Default Re: 1932-34 Model B Four Cylinder Group started!
Just jointed! want to learn more on the "B" block and what to look for
dustyp489 is offline   Reply With Quote
Old 12-14-2014, 10:14 PM   #102
EAV8
I have a "B" engine that I am planning to rebuild soon. I might put it in my "31 Town Sedan. Count me in, also. I am sure I will need some parts and advice. Gary
EAV8 is offline   Reply With Quote
Old 01-13-2015, 07:52 AM   #103
skryla
skryla's Avatar
B Engine for sale
http://www.fordbarn.com/forum/showthread.php?t=158053
Pics and description link above. Asking $975
skryla is offline   Reply With Quote
Old 01-13-2015, 12:44 PM   #104
larryf
I have a B with Miller Overhead in my 28 Special Coupe. How do I join the group?
larryf is offline   Reply With Quote
Old 01-13-2015, 12:52 PM   #105
Bob C
Follow this link. http://www.fordbarn.com/forum/group.php?groupid=80
Bob
Old 01-13-2015, 04:28 PM   #106
MrBruce
MrBruce's Avatar
This maybe a dumb question, but where it is and how do you go there? I see people saying they subscribe, but can't see it anywhere?
MrBruce is offline   Reply With Quote
Old 01-13-2015, 04:32 PM   #107
Juggler
Juggler's Avatar
Have you clicked on the link above?
Juggler is offline   Reply With Quote
Old 01-13-2015, 04:52 PM   #108
MrBruce
MrBruce's Avatar
Thanks, that works. Just getting ready to insert and build a touring B.
Old 01-13-2015, 05:20 PM   #109
Juggler
Juggler's Avatar
Excellent - post some pics?
Old 01-14-2015, 01:25 PM   #110
Hotrodfil
Hotrodfil's Avatar
Dragged a Diamond B out from the darkest recesses last night - planning a possible insert motor as well if funds can be raised...
Hotrodfil is offline   Reply With Quote
Old 01-14-2015, 04:50 PM   #111
CAPE A
Ok, Need info on B motors
1-Hp compared to a motor
2-how do i know i have a B block, Pan is off ,no crank ,no head , no flywheel housing.
3-What are the ser. #s
4-I think you can put an A head on a b block yes- no?
5-can i put an A pan on the B motor
6-Can i put the A flywheel housing on the B
7-Can you use an A dist. in the B
8- Are the oil pumps differnt
9-Can someone post pic of A vs B motor
Thanks for any help you can give CAPE A
CAPE A is offline   Reply With Quote
Old 01-14-2015, 06:11 PM   #112
Traintyre
Send a message via Yahoo to Traintyre
Originally Posted by skryla View Post
B Engine for sale
If you still have the B block etc for sale I am interested, but VERY far away: Oregon!
Traintyre is offline   Reply With Quote
Old 01-14-2015, 07:42 PM   #113
darrylkmc
darrylkmc's Avatar
50 vs 40
B has Fuel Pump boss about where the lower oil drain is located on an A
Model B engines typically do not have Serial Number
Yes, different water pump
Not without modifications, B pan on A requires removal of rear flywheel cover
Yes
Yes, but the Front timing Pin hole location is different
Yes, but an A Pump can be modified for use in a Model B
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 02-14-2015, 12:28 PM   #114
david berkeley
Lets do it. There is a great need for this specific group
david berkeley is offline   Reply With Quote
Old 02-17-2015, 11:02 AM   #115
Gwill65074
Gwill65074's Avatar
I have a 1937 diamond engine from a Gleaner combine, how would I tell if it is a B motor?
Gwill65074 is offline   Reply With Quote
Old 02-17-2015, 11:08 AM   #116
Tom Wesenberg
Tom Wesenberg's Avatar
Look on the right side towards the front for a hole for a fuel pump.
Old 02-17-2015, 11:24 AM   #117
Gwill65074
Gwill65074's Avatar
Thanks
Old 04-26-2015, 03:02 PM   #118
david berkeley
How can I join the group
Old 04-26-2015, 03:26 PM   #119
Juggler
Juggler's Avatar
See post 105 above and click the link
Cheers
Juggs
Old 04-26-2015, 07:14 PM   #120
ctlikon0712
ctlikon0712's Avatar
I just joined the group.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
