Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Does a part of the center divider have to be cut out to accommodate the wire to keep it from being cut into when putting the light back into the taillight section?
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
I installed some for a friend and didn't have to do any cutting.
Are there LED lights that look fairly stock when they are not on? I have seen some that really look out of place on a stock car.
These came from Snyders. The red wire that connect top board with bottom board cuts in the middle of the seperation.
#5 | |
Not sure what you meant by the last sentence, but, I cut the jumper wire [red]. There were no instructions stating that, but, apparently these lights are for other installations also. |
Yes, the ones I installed for a friend also needed to have the red wire cut.
I just installed these in my regular Model A teacup tail lights. They look pretty much like the original glass lenses. If you prefer, they come in red/amber also. Most of our guys (me included) opted for the all red, just to be consistent with what people expect.
I seem to remember if you install with the red wire not cut, all the LED's are on when the lights are turned on and become brighter when the brakes are applied.
When the red wire is cut, the upper and lower LED's are separated like the stock light, bottom side on with headlights, top side on with brakes. If using option 1, uncut wire, you need to modify the separator for the wire to pass thru. |
you don't even need the separator with the LEDs pictured. Notching it would cause no harm
'31 180A |
Got them in, did not cut any wire, brake light left works great, break light right does not work. Thought maybe I had cut the jumper red wire, took it back off, no cut, put the old bulbs back in, brake light still doesn't work. Put LED back on, running light left side works, gets brighter when brake is applied. Right side...nothing, no running nor stop.
The running light right side was working about ten days ago when I last ran Sarah, break light, can't say.
#13 |
Check your grounds...
#14 |
Will do first thing tomorrow when the garage has heat again.
#15 | |
Sounds like its time to get out the volt meter or test light. Once you the right side is working, I think you'll probably want to cut the red jumper. If you decide to hook up signals, that'll be fun. But, we'll get them working too. |
#16 | |
Just a bit of jocularity!!!! I'll put one on my shopping list for my next trip out. Sarah best not start talking diamond studded headlights!!!!!!Turn signals???? Started on them today too. Time for a cup of joe..................
#17 | |
I'll do some reading tonight in my A books about tail lights. -10 to -20 here tomorrow wind chill..................Brrrrr!!!
#18 | |
#19 |
I would certainly think so. That is the way mine is set up. I also have my center light, looks clear but has 12 5mm RED LED's in it.
#20 |
What could I have done, unknowing, that could have disrupted the electric flow to the right tail light? As I said, it was working just fine about ten days ago. The only thing I did electrical today was replace the terminal box top. It was cracked. Nothing else electrical.
| Thread Tools | |
| Display Modes | |
