Old 12-25-2014, 04:39 PM   #11
Synchro909
Synchro909's Avatar
Default Re: Tips For Model A's
Originally Posted by Dan Partain View Post
For those who haven't seen this before - To chase dirty or rusty threads, grind bolts with the same thread and run them into the holes that need cleaning. The sharp leading edge of the threads will do a pretty good job, and not ruin a good tap from grease/dirt combo. Regular hardware bolts work good for this and are cheap to replace when the threads get worn. I try to not use good A bolts if I can help it.
I've been doing this for years. Nowadays, I spend a little time getting the best edge on the treads as I can, then heat the bolt to bright red hot, almost yellow. Then drop it into a METAL container of oil.
This case hardens the bolt so long as it is a reasonable quality one in the first place and not one of those muck metal Chinese ones. You'll get much longer life out of it but makes sharpening it with a file pretty hard on the file (grind only).
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
