#41 |
Don't get rid of your spare parts...I've given away a ton of parts (and probably will continue to do so) only to find out later that I could use them on the next project that comes along. Trading parts is a great way to keep the cost of restoration down while meeting the guys on the forum.
#42 |
#43 |
#44 |
Buy and read books about your car (do not forget repair manuals )
#45 |
After timing, don't forget to replace the timing pin correctly.
#46 |
#47 |
Be very thankful if your mate shares your love of old cars and is willing to crawl under them to help you.
#48 |
always sell your A for a few dollars more then you paid........... brag to the wife as to how smart
you are and she will love you for it! better then being told no, when you go to buy your next A...................... |
#49 |
keep your issued box of depends under the seat in the storage compartment so nobody see's them
#50 | |
This case hardens the bolt so long as it is a reasonable quality one in the first place and not one of those muck metal Chinese ones. You'll get much longer life out of it but makes sharpening it with a file pretty hard on the file (grind only).
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
#51 | |
"read, read, read, ask questions, read some more." So that's the plan! Thanks, Kevin |
#52 |
Take lots of pictures with your digital camera. Pictures, the way everything is now - everything. Pictures, when you take things apart. Pictures, when you put it back together. You can't take enough pictures. When your mind gets foggy - you will be so glad you took those pictures. My mind get foggy a lot and pictures have saved me time and time again. Have fun, Bill
#53 |
#54 | |
Sorry missed the all apart oil pan off. |
#55 |
Locate your local Barner, I'm lucky here in the UK to have Juke Joint Johnny nearby
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog ![]() http://automotiveamerican.com/ |
#56 |
My best tip, always move spark lever up when turning off engine!
#57 |
#58 |
Think before you dive into a problem, you may make things worse.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
#59 |
I always install slide terminals in the headlamp and horn wires. In the event you need to replace the radiator you won't have to discombobulate the headlights and horn.
Crimp them on the wires with about 1 inch between them so you can still fish them through the conduits. Last edited by Skeezixx; 03-03-2015 at 11:09 AM. |
#60 |
When visiting the pub try to park facing down hill, or if it's flat reverse into parking bay and make sure you have a clear exit path. That way it makes bump starting easier when after a few drinks you realise you've got a flat battery because you left the lights on.
Oh and fit a battery master switch. |
| Thread Tools | |
| Display Modes | |
