Old 11-14-2014, 03:15 PM   #1
joltesvig
joltesvig's Avatar
Default 600R16 vs. bias ply tires
My 31 Coupe has the 16 inch wheels and I'm considering buying new tires for it.
Can anyone tell me if replacing the old bias ply tires with radial tires will improve the ride?
A set of radials will be about $120 more than the bias ones I think.
Are they worth it?
What do you think?
John the Model A Rookie from North Carolina
joltesvig is offline   Reply With Quote
Old 11-14-2014, 04:23 PM   #2
quickchange
quickchange's Avatar
Default Re: 600R16 vs. bias ply tires
Yes on our roads which are not as smooth as yours , 205 x 80 x 8ply, Some toyota , nissen pickups around 2010-2012 had them , cockies here take them off & fit mud grips , the light wall us radial tyres on two of our inports could not keep them on the road , too soft in the walls , fitted the above & at 120 kph stable as a modern plus they are taller than 600x16 , just my experiance , in NZ
quickchange is offline   Reply With Quote
Old 11-14-2014, 04:25 PM   #3
Marshall57
I haven't run them on my Model A, but on my old 50's cars I was worried that they would ride differently.
I did use them and liked the smoother ride, especially when first moving; the bias tires had a memory and would have a flat spot for a while until they heated up.
Also the radials looked a little funny, like they needed air but that is the nature of the beast. If you want that tall "on the tread" look you will not be getting it.
Most likely safer and easier to replace on the road if you have trouble.
Just my humble opinion.
Marshall57 is offline   Reply With Quote
Old 11-15-2014, 02:24 AM   #4
SSsssteamer
SSsssteamer's Avatar
I purchase the 600 X 16 radials from Coker tire two years ago. They have the correct profile for a 600 X 16. They handle better. They stop better. The give better tire and gas mileage. Other than not being the correct tire size for the model A year of manufacture, it is a no brainer to switch to the radials.
SSsssteamer is offline   Reply With Quote
Old 11-15-2014, 05:39 PM   #5
Paul from Maine
Paul from Maine's Avatar
I got sick of the rough ride my 4.50 x 21 tires were giving me so I scavenged four 15" wheels off a wrecked old Postal Jeep, mounted four 225 R75 15 Goodyear Wranglers on them, bolted two to the rear with no modification and mounted new front cast iron drums on the front hubs with longer studs and 1/4 inch wheel spacers and mounted the other two on the front! The Town Sedan now rides like a Caddy, handles like a Porsche and stops on a dime! I am exaggerating a bit, but the difference was like night and day! And the tires only cost $77 a piece! I will never go back to bias ply!
Paul from Maine is offline   Reply With Quote
