Old 10-13-2010, 11:40 AM   #1
Bobster
Bobster's Avatar
Default Oil Blowby
I am getting some oil blowby from my oil filler tube. Not real bad, but it makes the engine compartment messy. I assume I have the old type filler tube baffles in the tube because I have an early AR engine. Would the improved filler tube with steeper baffles work out better? I have also seen a cap that has a tube attached to vent the smoke / blowing oil under the car. Is this a good remedy? I am not concerned about excessive engine wear as a cause of the problem. Compression is 55 lbs or a little better on each cylinder. Spark plugs are not sooty / oily. My A has plenty of pep and I can climb a rather steep, curvy hill near my house in high gear. My neighbor has an old Chevy truck (6) that won't make the hill in 3rd gear. The cap with the vent tube might work. I just don't like gimmicks. What remedy did the old timer use? Thanks, BW
BW in WV
Bobster is offline   Reply With Quote
Old 10-13-2010, 11:48 AM   #2
V4F
V4F's Avatar
Default Re: Oil Blowby
the blow by tube was made for years to help that problem . also was told to use a 'pcv' valve to help , even on the open system ............... steve
V4f
V4F is offline   Reply With Quote
Old 10-13-2010, 11:57 AM   #3
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I have the flexable vent pipe and cap on mine. It works well. In my case it was raw oil droplets that came out of the filler tube and not smoke that messed up the engine compartment. The filler tubes were redesigined and enlarged in 1932 to eleviate the problem.
Barry B./ Ma. is offline   Reply With Quote
Old 10-13-2010, 12:00 PM   #4
Dan Baron
Dan Baron's Avatar
I find that an old sock over the breather tube will keep all the oil confined and the engine compartment clean. And will not cause oil pressure to build up and leak out the rear main seal. I tried the breather tube once and that caused the oil pressure to build up. It should hold you over until you decide to do something with the engine.
All I want, is a little bit more, than I'm ever going to get!
Dan Baron is offline   Reply With Quote
Old 10-13-2010, 12:37 PM   #5
Louis
mine was doing the same thing, oil on the fire wall and starter, and like your's it ran well,
i put a breather tube on it about 6 mo's ago, no more oil in the eng. comp.
the tube work's great for me, and easy to install.
Louis is offline   Reply With Quote
Old 10-13-2010, 12:57 PM   #6
bogdonj
bogdonj's Avatar
take the cap off and put a piece of a steel wool that use to clean dishes up underneath the tabs and from the inside of the cap in the center pull it down a bit. My engine use to flicker oil droplets out of this pipe and make a mess. Since I did this I have not had 1 drop of oil.
If you need a pic on how its done let me know
bogdonj is offline   Reply With Quote
Old 10-13-2010, 01:47 PM   #7
Ron/IA
bogdonj - I would like to see a picture. If you wish, post it here; or send it to [email protected]
Thanks,
Ron/IA
1929 Fordor Steelback
Hawk A Model A Ford Club
http://hawkamodelaclub.org/
Ron/IA is offline   Reply With Quote
Old 10-13-2010, 01:54 PM   #8
V4F
V4F's Avatar
i use a K&N filter on my filler . breathes well & helps control oil . i only have a small problem when going 55-60 mph for a long trip ............ steve
V4f
Old 10-13-2010, 07:28 PM   #9
bogdonj
bogdonj's Avatar
I will take a picture tonight and post it for you
Old 10-13-2010, 08:21 PM   #10
TinCup
TinCup's Avatar
Do you have a pic to share?
TinCup is offline   Reply With Quote
Old 10-13-2010, 10:58 PM   #11
bogdonj
bogdonj's Avatar
very easy fix!
Old 10-14-2010, 09:24 AM   #12
Dick Deegan
Dick Deegan's Avatar
My relatively fresh engine also will spit a little bit of oil on a long hard run. Even though the quantity is small, it still makes a mess.
bogdonj, thanks for the pictures.
Is this an old SOS pad that you used to stick up in the oil filler cap?
Also, I have another question for those who proposed the flexible vent pipe and cap. Do any of you use this with engine pans? How do you route the flexible pipe? Any rattles?
I visit this forum every day and it never ceases to amaze me how much I learn about the "A". Thanks to everyone for their contiued input and knowledge.
Dick
Dick Deegan is offline   Reply With Quote
Old 10-14-2010, 09:31 AM   #13
Ron/IA
bogdonj - Thanks for the pictures. I do appreciate it. I have oil blowby on my engine, but that is due to it being old and somewhat tired.
Again thanks,
Ron/IA
Old 10-14-2010, 09:42 AM   #14
bogdonj
bogdonj's Avatar
your welcome, Its not a SOS pad they are more steel wool but its a normal scrubbing pad. You can get them at any grocery store. Don't use any type of spounge or fabric that can rip apart. It's important to pull the pad down in the middle just to make 100% sure no oil happenes to slip by. Very cheap fix to fix a messy problem
Old 10-14-2010, 10:05 AM   #15
Benson
Dick
I ran mine down that square hole in the stock engine mount and clamped with supplied clamp to the steering column. But car never had any engine pans and it is a driver so I never noticed any extra rattles!
Old 10-14-2010, 05:06 PM   #16
Louis
the way i did mine.
Old 10-14-2010, 08:26 PM   #17
glenn in camino
glenn in camino's Avatar
I use an accessory piece called a Fumaze. It's a very nicely made breather that routs oil and fumes under the car. Most supplyers have them.
Old 10-14-2010, 09:07 PM   #18
TinCup
TinCup's Avatar
No search on the internet shows a fumaze breather.
Old 10-15-2010, 05:12 AM   #19
HoarseWhisperer
HoarseWhisperer's Avatar
Originally Posted by bogdonj View Post
very easy fix!
I too use the stainless steel scrubber pad in the cap with absolutely no blow-by.
If you want to keep the original appearance, you might want to read Brent's posts regarding the filler baffles in previous thread:
http://www.fordbarn.com/forum/showth...+filler+baffle
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 10-15-2010, 09:06 AM   #20
Dick Deegan
Louis;
Thanks for the pictures. You annswered my question.
Dick
