#141 |
The last time I saw a bearing break like that, the re-builder tried to file the rod cap to get the correct clearance. The egg shaped hole puts quite a train on the bearing.
TomO |
#142 | |
Super Moderator
I would not be surprised if a new block, etc. will be required in this instance. I simply can't imagine there's much remaining to work with on this one.
#143 |
What could have caused this?? Would it show up in oil changes??,noise?? It seemed it was driven quite abit, did it just eat itself up from bad machine work?? Pete
#144 |
I have no complaints whatsoever about previous work on my engine. I've driven this engine 50,000 very hard miles since those bearings were installed and have no reason to believe that there was any deficiency in previous work that caused this. The builder that installed them worked 40 years as a machinist in a diesel engine shop and was meticulous about clearances. He came highly recommended from several around the country including just recently by other Fordbarners. But, alas, he seems to have finally retired as he said he was going to after my 2008 rebuild.
Things just wear out, unfortunately. It's the natural consequence and price of having as much fun as I have with my car.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 09-12-2014 at 12:39 PM. |
#145 |
Good for you Prof!
Build em, drive the h_ _ l out of em, repeat... LOL That's what Flatheads are for... At least in my book.![]()
Imagination is more important than knowledge. |
#146 | |
I am usually relatively happy------Gary
#147 |
I agree that 50,000 miles is a decent service run, but that damage is more than just normal wear. Something let go in a big way to eat up those bearings like that.
#148 | |
#149 | |
Even though I'm going to let Paul order the parts, he seems to be open to any input I want to give him about things even though he may not act upon it. So, I'd still like to get anyone's recommendations of brands and sources for bearings so I can tell him in case he wants to check it out. Any suggestions?
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 09-12-2014 at 02:44 PM. |
#150 | |
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 09-12-2014 at 02:45 PM. |
#151 |
Lest anyone think that the "right mechanic" can get a flathead to last forever, even Ford didn't believe that. Here is the entry in the repair manual just before the instructions for removing the engine. Don't know how "used" an engine would have to be to get replaced but they weren't made to last forever.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#152 | |
#153 |
The weird mad-scientist side of my brain tells me the bearing failure was due to harmonics traveling through the crank from back-to-front. Old Henry drove with a bad u-joint for some time and on a downhill deceleration, that sends the stresses forward to the end of the line. Case in point: I know a guy who kept having his Toyota front pulley (harmonic type) come loose and ruin the key. No symptoms. Turns out his flywheel was loose. I've seen bearing fatigue like this isolated to one or two bearings but the cause was usually long-term detonation. Old Henry was always careful with his timing and jetting.
Lonnie |
#154 | |
#155 |
As far as bearings go, I'd try to find some old Ford cadmium-silver bearings.
#156 |
Finally, some helpful parts recommendations.
That's all I was really looking for. I'll pass those on to Paul in case he hasn't heard about them.
#157 |
I Agree something caused this engine to disintegrate its not Worn out in any way.
This engine needs to come completely apart,remove the cam bearings and front oil plug. And sent of to be cleaned properly. The clean out all oil channels. The Crank oil channels need to be cleaned to and the oilpump replaced, or disassembled and cleaned. One flake, is all its need to be in this situation again. And triple check the crank roundness and dimensions, same goes with the rods The engine must be so clean so You should be able to eat of it before you assemble it. Regarding the clutch, it looks that it could be badly adjusted so it slipped during normal driving, or that the driver rested his foot on the clutch pedal causing the clutch to slip. |
#158 |
I would talk to the people who are going to grind the crank what they prefer you use for bearings. I would consider having the connecting rods re-sized if it was my engine.
#159 |
Super Moderator
Consider? The way the rods were obviously hammering, it would not be a "consideration". At this point, it is a MUST.
#160 |
I think that any short cuts you may consider, will put you in the same shape you are now in, with more money wasted. I hate to see this considering the way you like to drive the old girl.
