Old 08-21-2014, 07:06 PM   #1
Old Henry
Old Henry's Avatar
Default Tell me this noise isn't what I'm afraid it is.
This noise started in the engine spontaneously a couple of weeks ago, barely perceptible. At first it seemed like it was just premature detonation so I tried the usual fixes: Pulled the choke out a bit. It seemed to help a little at first but as time went on I had to choke it almost to death - just barely able to run - to benefit at all. Put larger jets in the carb. Again, at first seemed to help but not any more. Cranked the vacuum brake on the distributor down as far as it would go. Again, only short lived benefit. Same with putting the highest octane gas available in. No help.
It has always had the characteristic of premature detonation - only exists at full vacuum under power over 40 mph, not when accelerating nor decelerating. Now it's heard at fast idle without any load after getting up to stable RPM as heard in the video.
I'm afraid that it is sounding more and more like the sound I had last year for a short time just before a piston came apart and I had to have the engine rebuilt (21,000 miles ago).
What do you think?
Here's the noise: http://youtu.be/1BXBh417e_w
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 08-21-2014, 07:33 PM   #2
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default Re: Tell me this noise isn't what I'm afraid it is.
Sounds like a rod knock to me, sorry
dean333 is offline   Reply With Quote
Old 08-21-2014, 07:34 PM   #3
mfagan
mfagan's Avatar
How's the oil pressure?
mfagan is offline   Reply With Quote
Old 08-21-2014, 07:35 PM   #4
Jack E/NJ
Jack E/NJ's Avatar
Dunno? I'd pull all the plugs first and see if they can tell you anything. If they all look the same, then pull the heads and take a look at and massage the pistons for bearing or wristpin issues.
Jack E/NJ
Old 08-21-2014, 07:35 PM   #5
Old Henry
Old Henry's Avatar
Oil pressure has always been good. New oil pump with engine rebuild last year.
Old 08-21-2014, 07:37 PM   #6
Old Henry
Old Henry's Avatar
Jack E/NJ
If I identify a bearing or wrist pin issue can it be fixed without removing the engine?
Old 08-21-2014, 07:45 PM   #7
ford3
almost every thing can be fixed with the engine in the car, except a flattened throw on the crank, sounds like a rod knock to me
ford3 is offline   Reply With Quote
Old 08-21-2014, 07:55 PM   #8
DJ513
DJ513's Avatar
I had a very similar noise an it turned out to be a broken piston. I didn't know it was broke till I pulled the piston completely out. Hope you have better luck than I did.
Dan
DJ513 is offline   Reply With Quote
Old 08-21-2014, 08:00 PM   #9
Lawrie
Lawrie's Avatar
Henry,I feel for you,you and me both do a lot of miles in our old fords,ours is resting at home as the engine couldn't,t be fixed in time for our big trip around Australia,so we are away in our fairlane.
Back to your noise,I too think it's a rod bearing. But to cheer you up,here is a pic we took the other day on our holiday ,a croc eating a kangaroo,I was going to go in for a dip till I saw this.
Lawrie
Lawrie is online now   Reply With Quote
Old 08-21-2014, 08:04 PM   #10
oldford2
oldford2's Avatar
Professor,
Pull one plug at a time and see if the knock stops or diminishes at any cylinder. If it is a rod this test would take all the pressure off the offending cylinder. Just a thought
John
oldford2 is offline   Reply With Quote
Old 08-21-2014, 08:05 PM   #11
Old Henry
Old Henry's Avatar
Lawrie
I was looking forward to the travelogue of your trip. Sorry you couldn't take it. Fortunately, this engine problem has just come after I have taken every road trip on my bucket list - 20 total over the last 3 years. I was just thinking I'll now have to start repeating them. Then this happened. It may be that I just take a rest from "Old Henry" for a while.
Old 08-21-2014, 08:07 PM   #12
Old Henry
Old Henry's Avatar
I was hoping that. It seems like if it's just a piston breaking or a rod or something like that I could take the head and the oil pan off and replace those parts without removing the engine. That's what Old Chuckles up the street has always done. I expect he'll give me a hand if I decide to do that.
Old 08-21-2014, 08:07 PM   #13
Old Henry
Old Henry's Avatar
Originally Posted by oldford2 View Post
Professor,
John
Good idea. I'll go out and do that right now and report.
I tried to identify the piston with the problem with a stethoscope but can't hear anything through the heads. It is definitely on the drivers side though.
Old 08-21-2014, 08:07 PM   #14
oldford2
oldford2's Avatar
deleted
Old 08-21-2014, 08:12 PM   #15
Old Henry
Old Henry's Avatar
Dan
I actually had worse luck than you last year when my piston totally broke apart, gouged the cylinder, and I had to have the engine rebuilt: http://www.fordbarn.com/forum/showthread.php?t=104413
Old 08-21-2014, 08:16 PM   #16
DJ513
DJ513's Avatar
Same here, Rebored all new parts. I had the machine work done and did the assembly myself. Was $$$$
Dan
Old 08-21-2014, 08:24 PM   #17
rheltzel
rheltzel's Avatar
I feel bad for you, Old Henry. But you'll figure it out, get it fixed, and be back on the road for more adventures.
rheltzel is offline   Reply With Quote
Old 08-21-2014, 08:34 PM   #18
Talkwrench
Talkwrench's Avatar
Bugger ! Sorry to hear Henry.. Mines out of action too at the mo'
NO swimmin' up there Lawrie too many snappy jaws!
Old 08-21-2014, 10:06 PM   #19
cmbrucew
cmbrucew's Avatar
Prof.
If not for bad luck, you would not have any.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 08-22-2014, 02:31 AM   #20
koates
Henry, For a quick test you could just pull off one spark plug lead at a time and see which cylinder causes the knock to go quieter. What a pain, always something going wrong with Old Henry. Regards, Kevin.
koates is offline   Reply With Quote
