Old 07-22-2014, 07:33 PM   #1
Pepsi Mechanic
Pepsi Mechanic's Avatar
Default steering wheel question
Been a while since I have been on .Is there any way of knowing what type of steering wheel I have , splined or keyed , on our early 28 AA without taking it apart ?It was built around March of 28 .
Pepsi Mechanic is offline   Reply With Quote
Old 07-22-2014, 07:40 PM   #2
glenn in camino
glenn in camino's Avatar
Default Re: steering wheel question
If it has a 28 steering column I'd bet money that the steering wheel is splined.
Old 07-22-2014, 07:50 PM   #3
Pepsi Mechanic
Originally Posted by 1930 coupe View Post
Look in the opening for the spark or gas levers behind the wheel and you can see the shaft.
Did not know that trick .. Thanks .. will check it out next week
Old 07-22-2014, 09:44 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
If the truck has the original seven tooth steering column it will be splined
