Guest
Posts: n/a
finally got my 46 running...... for about 20 mins. in driveway ne points. condenser. cap and rotor. voltage to input of dizzy, no spark at plugs. bad condenser??? can iswitch to ih200 napa?? 12v converion stocck crab distributor thanks mike |
Guest
Posts: n/a
The first thing that comes to mind is to ask whether you are running an ignition resistor with the change to 12V. If you don't have a resistor in line between the ignition switch and coil, you probably burned up the points. |
