Old 11-11-2013, 11:16 PM   #1
captonzap
Default Air filter question
The guy next block just bought a 29 A coupe.
It has a Marvel carb, but no air filter.
Did they come without one?
CZ
captonzap is offline   Reply With Quote
Old 11-11-2013, 11:30 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Air filter question
Correct, Model A's came with a cast iron Zenith carb with NO air filter.
Old 11-11-2013, 11:41 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Without a good flow of air the engine will not run as well as it could. Filters that are oily dirty, or just too small can give problems with the balance of the carb.
Old 11-12-2013, 02:01 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
Mike V is right on. Too much filter will cause loss of power and cause the spark plugs to run black and sooty. Henry didn't think that it needed a filter. I don't run a filter on any of mine.
Old 11-12-2013, 08:55 PM   #5
glenn in camino
glenn in camino's Avatar
On one of my Model As, I have a K&N air filter mounted under the carburetor. So far, no problems. It also has an Afordable oil filter. I'm hoping this engine will last a long time.
Old 11-13-2013, 10:15 AM   #6
captonzap
Thanks guys. I'll suggest that he gets a big sock type filter. We can rig up a support off of the manifold.
I've ruined a few motorcycle engines by running them without filters. Ring and land wear gets out of hand.
CZ
Old 11-13-2013, 12:06 PM   #7
mhsprecher
mhsprecher's Avatar
Based on other threads here, I replaced my air maze filter with this one from eBay. http://www.ebay.com/itm/The-Original...c834ed&vxp=mtr
The car runs much better and if there is gas dripping out of the carb, it doesn't soak the filter. I have not checked my plugs since, but there has not been one thing that I have done to my car to make it run better than to swap out the air maze for this. Many folks will say that you don't need an air filter, but I prefer one, even though there is probably not as much dust in the air now as there was when the A was new.
mhsprecher is offline   Reply With Quote
