Old 09-13-2013, 04:39 PM   #1
A V8 Al
Default 260 V8 choke heat tubes
The two choke heat tubes on my 260 V8 Falcon Sptrint have rotted and broken off at the point they enter the exhaust manifold. What is the best way to remove the remaining tube from the manifold. Also, how are the new tubes secured to the manifold holes?...is it fust a pressure fit? Thanks, Al
A V8 Al is offline   Reply With Quote
Old 09-13-2013, 05:48 PM   #2
Blue Futura
Blue Futura's Avatar
Default Re: 260 V8 choke heat tubes
I drilled mine out on a 289 , very careful so i would no oversize it. Then just installed another new one . It fit's a little loose but stays in and works good .
64 Futura , bought new.
56 ford fairlane , bought about 30 years ago.
35 chevy street rod , started building in 2000.
Blue Futura is offline   Reply With Quote
