Old 06-02-2013, 12:15 AM   #1
denson1932
denson1932's Avatar
Default 1954 Mercury teapot carb troubles....
Advice needed...I disassembled the carb. part-way and found (2), not one small ball bearings as check valves in the accelerator pump circuit? or did I not notice and one came from some different port?
I have a high speed miss that is driving me crazy...when I rev the engine up even in my shop (so no load) the thing spits and backfires somewhat...is the problem in the power circuit or does it need bigger main jets???
I thought the power valve is just enabled during heavy pull like up a hill...
My buddy thinks there should be a metal sleeve around that weird carb so it can act like a regular carb....
Also all the old foam in the air cleaner had turned into turd like material so I had to remove it all and so now I have some breathable foam in air cleaner to act as normal restriction would be...
thanks in advance for any info.
denson1932 is offline   Reply With Quote
Old 06-03-2013, 08:12 AM   #2
Bill Steiner
Default Re: 1954 Mercury teapot carb troubles....
Hi ,I sent a reply to your private message I got. Not sure I did it right . Hope it sent to you. Bill
Bill Steiner is offline   Reply With Quote
