Old 05-30-2013, 02:12 AM   #41
LSJUNIPER
Default Re: Flathead project
Thanks Mart,
LSJUNIPER is offline   Reply With Quote
Old 05-31-2013, 01:22 AM   #42
40 Deluxe
Looking at the earlier photos, I see that the engine has an internal coating of that special black protective substance (some call it sludge, but I think it's a flathead's way of protecting itself during longterm outside storage). Maybe there's even a Ford part number for it?
Old 05-31-2013, 03:26 PM   #43
KiWinUS
KiWinUS's Avatar
Originally Posted by quickchange34 View Post
I think you need to get it off that motor stand ASAP. You may find it in the floor, if not now its a good chance when you start swinging a wrench on it. The rear of the blocks on the 48 and back cant stand the pressure.
Old Wives Tale !!!!
been building them for 40+ years on a stand like that !
Have 6 on stands at the moment !
Old 05-31-2013, 04:23 PM   #44
hope
hope's Avatar
Originally Posted by KiWinUS View Post
Old Wives Tale !!!!
Why take chances!!!!!!!!!
hope is offline   Reply With Quote
Old 06-02-2013, 04:55 PM   #45
LSJUNIPER
haha 40 Deluxe, there was a lot of that black protective coating inside that motor too. Speaking of coating, I just pruchased POR-15 engine enamal for the block. I have read that some people use a base coat before using the engine enamal, if so what is the base coat???
Old 06-02-2013, 05:20 PM   #46
LSJUNIPER
Didn't want to take a chance putting the motor back onto the stand the way I first did. So I modified the stand to hold the motor by its exhaust ports. Per quickchange34s' advice, didn’t want to chance it. Then I added another caster wheel to it from 3 casters to 4 , for stability. See the pics .
Thanks
Old 06-02-2013, 05:53 PM   #47
KiWinUS
KiWinUS's Avatar
after all these years & dozens of engines ....... like I said "An old Wives Tale " not even about taking a chance !!!!
Old 06-02-2013, 08:00 PM   #48
LSJUNIPER
Kiwinus do you have a website for your shop? Sounds interesting.. This is my first Flathead.
Old 06-17-2013, 10:44 AM   #49
LSJUNIPER
Some progress this weekend.
Painted the block and attached it to the motor stand.
Old 06-17-2013, 02:02 PM   #50
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Just a reminder about supporting that engine....I've read plenty of horror stories here on The Barn about broken bell housings and smashed tootsies. That type of stand is not good for a flathead.
dean333 is offline   Reply With Quote
Old 06-17-2013, 03:34 PM   #51
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
That paint better not be Chevy orange, if so it will never start say nothing about running. Walt
Old 06-17-2013, 07:54 PM   #52
LSJUNIPER
Nope. It's not Chevy orange....the engine is supported from the exhaust bolts...thanks for your advise.
Old 07-31-2013, 10:36 AM   #53
LSJUNIPER
Starting to reassemble the motor!!
Old 07-31-2013, 04:14 PM   #54
GreenMonster48
GreenMonster48's Avatar
How was Eastwoods to deal with? I live nearby. I ended up taking my Flathead to Earl's in Stafford. Still waiting.
GreenMonster48 is offline   Reply With Quote
Old 08-01-2013, 04:25 PM   #55
LSJUNIPER
I am pleased with Eastwoods work, I would go back if I ever decide to build another motor. They have a facebook page, check it out.
Old 08-01-2013, 04:51 PM   #56
Fredb_
Fredb_'s Avatar
Nice work on the engine! I have the original 81A that was in my 38 Sedan. I hope to do something similar during some future Oregon Winter days. I currently have a rebuilt 1946 59 block in my car and it runs pretty nice. Nice pictures, thanks!
Fredb_ is offline   Reply With Quote
Old 08-01-2013, 09:10 PM   #57
Bluebell
LS Juniper, I see the block is tapped and plugged with an extra plug above the oil sender boss (casting lump) Just be sure there is no plug blocking the cross drilling.(inside the horizontal drilling) It would stop oil flowing to your crankshaft.
The Canadian military engines were built like this for its 28,000 Bren carriers, because they ran an external oil cooler. The U.S. supplied engines for Australia's 8000 carriers as well as 1100 for New Zealand's carriers. (all of these were 239c.i.) Along with these many 221's were supplied to the U.K. All these engines had that extra drilling. I don't know how many were produced for local (U.S)applications in this configuration. There were obviously quite a few. The plus is, it allows the fitting of a near full flow filtering system, without serious mods.
Walt has a few clips on you tube about those drillings. Be careful.
Bluebell is offline   Reply With Quote
Old 08-02-2013, 04:44 AM   #58
LSJUNIPER
Thanks Bluebell,
When I get home form work today I will take a closer look.
Old 08-02-2013, 04:51 AM   #59
LSJUNIPER
Thank you Fredb, This has been a fun project, can't wait to finally start it up.
Old 08-02-2013, 06:07 PM   #60
LSJUNIPER
Got a question, should I use the split type retainers on the valves, or should I go with the solid type? I put an isky cam in. It's the 77-b. I read that the split retainers can separate and do damage to the motor.....l don't want to mess this up....Thanks
