Old 05-06-2013, 11:35 AM   #1
Jim Kroeger
Default How to diagnose a bad coil?
Is there a way to tell if the coil is on its way out on my 30 Model A? I know you can check for 6v at each terminal with a meter but will this diagnose if it is bad? Can they slowly start to falter therefore fooling you into thinking it is something else that is the problem on a rough running engine or once they go they go and the engine won't run anymore? Any adivice?
Jim Kroeger is offline   Reply With Quote
Old 05-06-2013, 11:49 AM   #2
Mitch//pa
Default Re: How to diagnose a bad coil?
i have seen them test good but when hot act up. they can be intermittent and i would just plug another one on if you suspect a problem. its always good to carry a spare anyway
Old 05-06-2013, 12:45 PM   #3
Kevin in NJ
The only simple way to test a coil is with a coil tester.
Checking voltage and resistance is just not testing what fails.
A coil tester is just some kind of repeating make break device to make a spark across an adjustable gap. It should also allow current to flow for a little while to let it warm up. Most coils are only bad when they are warm.
You can buy coil testers or build one yourself.
How to build a coil tester.
Old 05-06-2013, 01:15 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
HERE is what my coil tester looks like. It is a must because units that have tested good with driving or with VOM will show up as marginal once they have been heated & tested.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-06-2013, 02:31 PM   #5
ford3
here is my non scientific way of finding a bad coil, if you cant keep your hand on it after the engine dies because its to hot to handle, its bad
ford3 is offline   Reply With Quote
Old 05-06-2013, 05:38 PM   #6
pooch
pooch's Avatar
Hook a timing light to the coil wire and drive and watch the flashes.
pooch is offline   Reply With Quote
Old 05-06-2013, 07:28 PM   #7
bhiland
Agreed.
bhiland is offline   Reply With Quote
Old 05-06-2013, 07:59 PM   #8
BRENT in 10-uh-C
Originally Posted by bhiland View Post
Agreed.
The coil I showed in that link above that I was testing is a coil however it won't get warm at all (much less hot). It even throws a blue spark ...just not very far, -and not very well under an extreme load causing the engine to skip and not produce all the power it was capable of.
So, why doesn't the "hand test" pick up on this substandard coil? One other question, if the hand test is/was accurate, then why were so many coil testers sold??
What I learned is there are quite a few poor to "just OK" coils out there. Once you find a good one, they make a world of difference.
BRENT in 10-uh-C
Old 05-06-2013, 08:20 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Brent I couldn't get the link to open, so I don't know what your coil tester looks like. I assume it has a condenser built in to fire the coils, and it may be bad, especailly if the tester is quite old.
Old 05-06-2013, 08:25 PM   #10
BRENT in 10-uh-C
Tom, my coil tester works great! Here is a direct link to it;
https://fordbarn.com/forum/showpost.php?p=336459&postcount=7
BRENT in 10-uh-C
Old 05-06-2013, 08:50 PM   #11
ford3
LOL brent, when your out on a cruise you dont have the benifit of a trunk full of shop test equiptment, so you have to rely on the old fashion way to try and find the problem, a very hot coil is one indicator its bad, another is when it cools down and engine restarts you can figure its bad
Old 05-06-2013, 09:31 PM   #12
Tom Wesenberg
That took me to the same place as the link in #4, which says I need to sign in and give my password to have access. Too much monkey business and I'd have to find my password. I wrote it down somewhere.
Old 05-06-2013, 10:09 PM   #13
Mike V. Florida
Mike V. Florida's Avatar
Old 05-06-2013, 10:18 PM   #14
Tom Wesenberg
Thanks Mike. I'm surprized Brent hasn't had better luck with the coils he's tested.
All the Model A coils I've picked up over the years have had excellent spark.
Old 05-07-2013, 02:15 AM   #15
BRENT in 10-uh-C
I agree. After buying that tester a few years ago, I went on a buying spree of coils. This was also during a time when Ahooga was not making the repro coils. The coils I had were all testing kinda weak and at that time I wondered if it was the norm. Even the "NOS coil" was not strong so I was questioning whether the tester was any good. After buying a brand new coil along with several other used ones, I quickly found the tester worked properly. Again, the units I did have would spark, just not at the full potential.
BRENT in 10-uh-C
Old 05-07-2013, 04:57 AM   #16
MikeK
MikeK's Avatar
1930 "SP" Model A coil
MikeK is offline   Reply With Quote
