Old 04-17-2013, 12:39 PM   #1
ford35lh
Default aluminum head erosion
What is the cause of erosion around the water holes on an aluminum head ???
Coolant quality or galvanic action ???
Does this take place on the entire coolant surface inside the head ???
thanks
lynn
ford35lh is offline   Reply With Quote
Old 04-17-2013, 12:52 PM   #2
36tbird
Default Re: aluminum head erosion
electrolysis between dissimilar metals. add some copper head gaskets to enhance the process.
36tbird is offline   Reply With Quote
Old 04-17-2013, 01:59 PM   #3
hotcoupe
hotcoupe's Avatar
use a piece of magnesium as a sacrificial anode in the cooling system! the magnesium will be attacked before the aluminum. hope this helps.
tom
hotcoupe is offline   Reply With Quote
Old 04-17-2013, 04:20 PM   #4
34ragtop
should we use copper gaskets or regular ones?????
34ragtop is offline   Reply With Quote
Old 04-17-2013, 05:19 PM   #5
mrtexas
mrtexas's Avatar
Use a magnesium anode and then use any gasket you want. Use anti-freeze as well. They are about 2 inches long and an inch wide. I use one with an aluminum head.
This is not a new or big concern. All modern engines have cast iron blocks or aluminum blocks with steel sleeves and aluminum heads.
mrtexas is offline   Reply With Quote
Old 04-17-2013, 06:34 PM   #6
19Fordy
19Fordy's Avatar
Where can I buy a magnesium anode or get a little piece of magnesium? Thanks.
Old 04-17-2013, 06:42 PM   #7
hardtimes
hardtimes's Avatar
Any hardware store that sells water heaters , for home/motorhome water heater use sacraficial anodes and you can cut them to size if too long (usually 1" diam x 5". Probably other applications can be used also.
Old 04-17-2013, 07:00 PM   #8
hotcoupe
hotcoupe's Avatar
VW engine blocks are Magnesium, if you have access to one.
Old 04-17-2013, 08:52 PM   #9
mrtexas
mrtexas's Avatar
Macs sells them.
Old 04-17-2013, 09:55 PM   #10
columbiA
The early 21 stud heads were made of a poor grade of aluminum and the heads would often corrode themselves to the studs.It was not uncommon to have to smash the heads with a sledge hammer & punch & remove them in pieces.
columbiA is offline   Reply With Quote
Old 04-17-2013, 09:59 PM   #11
paleot
Cummins or Detroit Diesel dealer should have what you are looking forbolt right into head or heater hose fitting on water pump.
Tony
paleot is offline   Reply With Quote
Old 04-17-2013, 10:00 PM   #12
ford35lh
OK, the first question answered. Thanks.
Does this erosion take place only in close proximity to
the iron surfaces or is it just as bad on the whole
interior of the head ???
lynn
Old 04-18-2013, 10:39 AM   #13
TJ
TJ's Avatar
Electrolysis attacks the entire inside of the head. It can also plug up your radiator.
TJ is online now   Reply With Quote
Old 04-18-2013, 11:42 AM   #14
woodiewagon46
I remember in one of the street rod mags an article about a company that makes radiator caps with a sacrificial anode attached with a stainless cable, I'll research it.
woodiewagon46 is offline   Reply With Quote
Old 04-18-2013, 11:50 AM   #15
jkeesey
jkeesey's Avatar
columbia hit it on the head, the early aluminum heads were made of a bad alloy. The more modern aluminum can handle electrolysis much better. A customer of mine found a company in California making original heads with modern materials, im sure someone on here has the info.
jkeesey is offline   Reply With Quote
Old 04-18-2013, 11:58 AM   #16
Andy
I put a set of new Eldebrock heads on and had to remove them about a year later. The electrolisis had almost ruined them. I had always had good anti freeze in the engine. The cylinder block was extreamly clean inside. I went back with graphite gaskets.
Andy is offline   Reply With Quote
Old 04-18-2013, 12:10 PM   #17
B-nut
Kearney Pattern and Foundry inc. San Jose, Ca. makes really nice aluminum heads. Have a pair on a 35 that I am very happy with after worrying about the old corroded heads for years.
B-nut is offline   Reply With Quote
Old 04-18-2013, 12:17 PM   #18
flatjack9
flatjack9's Avatar
I had a set of the new block letter heads on my engine for a year. Took them off and they were just like new. Also used copper gaskets.
Old 04-18-2013, 02:09 PM   #19
FlatheadTed
FlatheadTed's Avatar
(1) poor metal in original heads
(2) copper gaskets
(3) Some Anty freeze has a short use life ,like 12 months then it becomes corrosive .
(4) it does corrode inside but more so were copper meets the head
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-19-2013, 01:05 AM   #20
49r
In 1975 I put some NOS Canadian higher compression alloy 8BA heads on my motor. Took them off 8 months later when things got noisy after a valve seat fell out. One head bolt had frozen to the LH head and the only way I could get it out was by rotating the whole head. I was a teenager who didn't know about water additives or sacrificial anodes. Would either have helped?
49r is offline   Reply With Quote
