Old 03-07-2013, 05:07 PM   #1
AlanD
Default Carb bowl gasket
Would someone measure the gasket going between the bowl and the body on the Holley and Kingston carburetors?
Thank you!
Alan
AlanD is offline   Reply With Quote
Old 03-07-2013, 08:17 PM   #2
Steve Jelf
Steve Jelf's Avatar
Default Re: Carb bowl gasket
Which Holley? Which Kingston?
Steve Jelf is offline   Reply With Quote
Old 03-07-2013, 09:21 PM   #3
yachtsmanbill
yachtsmanbill's Avatar
Get out the calipers and measure it, then get a good gasket cutter. EEZY PEEZY! ws
http://www.grainger.com/Grainger/ALL...tter-Kit-3KGV5
Indespensible! Found a kit on ebay for $20
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 03-07-2013, 11:39 PM   #4
AlanD
Steve, I didn't know there were different versions used on the Model T. Synder's shows a couple of different gaskets so I was hoping one would be the size I need, which is ID = 2.625, OD = 2.725, thickness = .025
I'll just ask them to measure the ones they sell.
I did cut my own gasket and it will work, but it could be better - ya know.
Old 03-08-2013, 11:48 AM   #5
Steve Jelf
Steve Jelf's Avatar
Yep, the Holley G and the Holley NH are very common Model T carburetors, and the bowls are very different sizes. There are also several Kingstons, but I haven't compared their bowls. The T was made for nineteen years and used a lot of different carbs. Many of them, especially after 1920, have a nameplate that identifies them.
