Old 02-04-2013, 09:53 AM   #1
Step-down
Step-down's Avatar
Default ZZ-Top Strips Gone after 10 Years
I thought I would post how to:
This isn’t anything new but over the weekend I removed some very much needed striping from my 39' five window...
Technical:
Before and After photo of the car below. Easy Off oven cleaner was used to remove the strips that have been on the car for 10 plus years. Mask off chrome and clean up well with water base cleaner after strips are removed. My car had clear coat over base color and believe could be an issue if you don’t have clear coat. Simply spray on area and time for 5 minutes, wipe off and repeat if necessary. Wet Sand with 1500 with water in area that require, followed by light white polishing compound.
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 02-04-2013, 10:13 AM   #2
19Fordy
19Fordy's Avatar
Default Re: ZZ-Top Strips Gone after 10 Years
Looks much better, but using OVEN CLEANER scares me.
Old 02-04-2013, 10:19 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
I've done it in a somewhat similar fashion, except for the SPRAYING-on part. First of all, the YELLOW can is the one to use (not the black can). I use a wet (dip in water, first) Q-TIP which I then dip into a small container which I've sprayed a small amount of the can's contents into. Wipe the pin-striped line with a dampened (with water) cloth. Then, paint the portion of pin-stripe line that you want to remove. Like said above, wait about five minutes, then wipe thoroughly with a wet rag to remove the line of pin-stripe. No overspray mess to deal with. ALWAYS try a test on an obscure portion of your paint to make sure there will be no ill effects on your paint BEFORE attempting the main mission. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-04-2013, 10:46 AM   #4
Blu Dice
Blu Dice's Avatar
Some colors are harder to remore than others (red) and also after the stripes or lettering are removed you will see the ghost in the paint - color sanding and/or rubbing compound will take care of this
Blu Dice is offline   Reply With Quote
Old 02-04-2013, 03:55 PM   #5
hardtimes
hardtimes's Avatar
Hey Step-down,
Thanks for the pics/instructions! Great job also.
That stuff is really good for a lot of uses! One cavaet tho...wear some breathing protection when spraying. One whiff of that stuff will definitely get your attention..to not do that again.
Old 02-04-2013, 04:05 PM   #6
Mart
Mart's Avatar
That looks SO much better.
Mart.
Old 02-04-2013, 04:13 PM   #7
Bassman/NZ
Bassman/NZ's Avatar
Originally Posted by mart View Post
that looks so much better.
Mart.
+1....
Bassman/NZ is offline   Reply With Quote
Old 02-04-2013, 05:43 PM   #8
1937pickup
What about heat from a hair dryer or other type-I hate when car dealers put their emblem on my cars. I don't want to be a rolling bill board for them without re-imbursement. I use a hair dryer to peal them off-always seem to come off easily.
1937pickup is offline   Reply With Quote
Old 02-04-2013, 05:59 PM   #9
VeryTangled
VeryTangled's Avatar
Mart said it!
-VT/Jeff
Old 02-04-2013, 06:33 PM   #10
rattlesnakehoey
From ZZ top to top of the class. A lot of those 80's & 90's styling cues don't date well.
rattlesnakehoey is offline   Reply With Quote
Old 02-04-2013, 06:39 PM   #11
Step-down
Step-down's Avatar
1937 PU ....Heat gun works great ...I've used that method on vinyl ....My application was painted on with one shot some time ago.
V8CM brings up a good point beware of the overspray and clean/clean up the overspray or be neat .....
Old 02-04-2013, 06:44 PM   #12
quickchange34
quickchange34's Avatar
Great job. That yellow can oven has alot of uses.
quickchange34 is offline   Reply With Quote
Old 02-05-2013, 08:15 AM   #13
Blu Dice
Blu Dice's Avatar
What else?
Old 02-05-2013, 08:33 AM   #14
BERNIE G
BERNIE G's Avatar
And all this time I've been trying to save a ZZ TOP bumper sticker on my 51 Prefect. I must be old school.
BERNIE G is offline   Reply With Quote
Old 02-05-2013, 08:42 AM   #15
oldskool
oldskool's Avatar
I use to clean carbs for rebuilding,takes off years of crud, just rince well with hot water,use rubber gloves this stuff will take skin off...
oldskool is offline   Reply With Quote
Old 02-05-2013, 05:41 PM   #16
HOTRODPRIMER
HOTRODPRIMER's Avatar
Big improvement! HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 02-05-2013, 06:07 PM   #17
1937pickup
Thanks Step Down- I assumed it was vinyl and you know what happens when you assumed.
