Old 02-03-2013, 10:00 PM   #1
40ford
40ford's Avatar
Default 40 Instrument Panel (Standard):
I am going to give the instument cluster in my 40 standard a face lift.Has anyone used the decal kits that are sold for the gauge faces?What is the color of the plate that goes around the gauges and where can the paint be purchased?Can the new speedometer face be installed without taking the needle off?Has anyone been here and done this? Thanks,Russell
40ford is offline   Reply With Quote
Old 02-03-2013, 10:45 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 40 Instrument Panel (Standard):
Russel, The decals are "okay" at best.The colors are not quite accurate.
However, if you can't locate NOS gauges, it is perhaps your best option.
You must remove the needle from the speedometer face and the metal "faces' from each of the gauges to apply the vinyl decals.
I will check (tomorrow) and post here what paint color is a good match for the cluster bezel background area.
Old 02-04-2013, 08:56 AM   #3
296 V8
In one of his recent sale flyers Drake was offering (“coming soon“) new gauge faces.
Iv changed them before …. nothing to it / super easy
296 V8 is offline   Reply With Quote
Old 02-04-2013, 09:24 AM   #4
4dFord/SC
4dFord/SC's Avatar
Probably the hardest part is the contortions required to remove and then reinstall the cluster.
4dFord/SC is offline   Reply With Quote
Old 02-04-2013, 03:16 PM   #5
Ken Crans
Ken Crans's Avatar
Russell,Getting the speedo needle off is the hardest part. Macs has the decals. I used a sandy color duplicolor rattle can for the plate. Came out beautiful. Good luck Ken
Ken Crans is offline   Reply With Quote
Old 02-04-2013, 09:05 PM   #6
34flathead
34flathead's Avatar
i have one in my little pickup, in and out a couple times but i can take my seat out and use blocks to raise up to the level of the seat riser.
that way i dont have to contort this pushing 60 back that much.
you should be able to get it once you see where the mounting screws are it will come right out, remove the light sockets so it will come all the way down.
rich
34flathead is offline   Reply With Quote
Old 02-09-2013, 09:44 AM   #7
std1940
std1940's Avatar
Question Re: 40 Instrument Panel (Standard):
Mike,
What is the paint color you recommend for cream background area?
Thanks Tom.
std1940 is offline   Reply With Quote
Old 02-09-2013, 01:14 PM   #8
4dFord/SC
4dFord/SC's Avatar
Originally Posted by std1940 View Post
Mike,
Thanks Tom.
I used Rustoleum "Painters Touch" Ivory on mine.
Old 02-09-2013, 02:37 PM   #9
mike in las vegas
mike in las vegas's Avatar
I went to rattlecan alley and took in the cluster to match. I used a roll of pin stripe to try to look original. It's not quite right only we know. Everyone else loves it. Guage decals were used. See the picture in my only album....
mike in las vegas is offline   Reply With Quote
Old 02-13-2013, 11:47 AM   #10
40ford
40ford's Avatar
Gauge cluster looks very nice Mike.
Old 02-14-2013, 09:12 PM   #11
ctaulbert
ctaulbert's Avatar
I just did mine over the past couple of nights:
ctaulbert is offline   Reply With Quote
Old 02-14-2013, 10:27 PM   #12
Lawson Cox
Lawson Cox's Avatar
Neat job. Congratulations.
Old 02-15-2013, 01:10 AM   #13
mike42
mike42's Avatar
Ctaulbert.......my '40 has a small water mark and started to take it out, but decided against it after awhile. Any secrets to know about a easy removal ?
That really looks nice !
Mike
mike42 is offline   Reply With Quote
Old 02-15-2013, 07:40 AM   #14
ctaulbert
ctaulbert's Avatar
Mike - I'm rewiring the car, so I was cutting most of the wiring out. The harness along the back of the dash does somewhat block a clear path of removal, but overall, it's not too hard to remove.
There are four nuts and clamps on the back side. Remove those, disconnect the wiring, and push the cluster toward the firewall.
There are four metal tabs that are folded over the chrome bezel, which hold the front of the cluster together to the cluster panel. You can unfold them easily with a screwdriver, and disassemble it from there.
Hope that helps.
Old 02-15-2013, 12:31 PM   #15
mike42
mike42's Avatar
Hey CT...thx. I got as far as removing two of the nuts and started looking at where this thing was going to go after I got it unbolted ! That's when I stopped. I'll look at it again in warmer weather, as your cluster looks great.
Thanks.....Mike
Old 02-15-2013, 02:06 PM   #16
TomT/Williamsburg
TomT/Williamsburg's Avatar
With the Chrome bezel you really only have to undo 2 of the tabs - the 2 on the top or the 2 on the bottm - the other 2 can just be loosened.
If you do not intend to go back to completely stock, there's a great thread on the HAMB regarding redoing the 40 std gauge cluster. Might just be (or a portion there of) what you are looking to do. I've started one for my 40 p-up project ....
Here's the link:
http://www.jalopyjournal.com/forum/s...d.php?t=676488
You might have to join the HAMB to see this thread - just do so, do a small intro, and start lurking. Many of the same folks are on here and you would be surprised how many, many of these guys really dig stockers and saving stockers ....
TomT/Williamsburg is offline   Reply With Quote
Old 02-15-2013, 02:57 PM   #17
mike42
mike42's Avatar
TT....
Thanks for info. I want to clean it up and leave stock, as the car is stock. There were just so many wires under there I could not figure out which way it would come out.
I'll be down your way with my Wife in April staying at the Williamsburg Inn for a week. We also are going to Monticello.
Thx for the link....Mike
Old 02-15-2013, 03:13 PM   #18
TomT/Williamsburg
Originally Posted by mike42 View Post
TT....
No problemo, Mike - I'm gone most of the last week in April (Spring Carlisle - T-Fri) but there's a pretty nice show in town the last Fr-Sat in April and I'll be at the show that Sat - what dates are you looking at being my way? Hopefully we can get together and do some flattie bench racing .... let me know and maybe, if you have time, we could visit a couple guys garages here in town ....
Old 02-15-2013, 06:39 PM   #19
mike42
mike42's Avatar
TT..... I'll look at my schedule and let you know.
Mike
