Old 12-17-2012, 09:11 PM   #1
trainguy
trainguy's Avatar
Default tranmission oil
The second gear syncro on my 46 ford is not working as it should, making shifting very slow.I am using 90-140w gear lube.I wonder if switching to a thinner lube help make shifting better or not.Oppinions?Thanks Phil
trainguy is offline   Reply With Quote
Old 12-17-2012, 09:56 PM   #2
Dee
Default Re: tranmission oil
I think the second gear sychro brass blocker ring is probably worn and changing the transmission oil to something lighter might make things worse.
Dee is offline   Reply With Quote
Old 12-17-2012, 11:56 PM   #3
columbiA
When the brass syncro rings get worn to the point that the front face contacts the side of gear before the inner cone of syncro contacts cone on 2nd-or high gear,it will act like a non-syncro trans& require double clutching to shift without grinding.The rings should have around .015" clearance when pushed onto the gear.When the fine grooves are worn off the inside of syncro rings,they are worn out.
columbiA is offline   Reply With Quote
Old 12-18-2012, 11:34 AM   #4
Butch11443
Butch11443's Avatar
Try straight 140 weight. Older syncros need the heavier oil.
Butch
Butch11443 is offline   Reply With Quote
