Need help ! I am recently experiencing starting problem after driving a short while. The engine will stop or after stopping will not start again,,,but wait a hour or so and will start again. Its a 35 Ford roadster with 39 V-8 with Mallory electronic dist, twin NEW stromberg carbs on Edmunds intake, Eldebrock heads and electric fuel pump. Did run great at first (100 miles of short trips) but last 2 runs were not good.... Any ideas...fuel pump working and pressure set at 3 psi...Any help would be appreciated..thanks Steve G.
Could well be a marginal coil or condenser checking out when hot.
Engine starting happily later suggests that carbs are still full and able to function, but here's a simple test: With engine in no-start mode, put a small splash of gas or a shot of starting fluid down the throats. As you crank, engine shoulf arrive at a burnable mixture and try to start if fuel supply is the problem...I'm pretty sure your problem will prove to be ignition parts on their way out. PS...Mallory condensers are as marginal as their points in my experience...the condensers hav very short electrical lifespan AND they have grounding problems due to a shellac-looking coating on the can. |
as Bruce said.....and check spark at a plug when you get the no-start problem...good luck.....Mike
My experience with dying coils, something that confused me for a long time, is that you will see a spark on testing but the spark is not adequate to run the engine.
The dying coil spark is thin and yellow, while a good spark is fat and blue. The real diagnostic is trying a different coil! So far, I have not had a problem I could blame on a condenser...but I have heard a lot of bad things about these late Mallory condensers and know from personal consultations that the points are junk, often good for less than 1,000 miles before rubbing blocks are gone. |
My 2 cents is that a faulty condenser will allow a engine to start but it will break down badly when trying to increase RPM. I had a engine that would idle well but put a small load or try to rev it and it would die, A bad coil will no doubt be the problem with hard starting hot.
new mallorys are junk, and they know it. to bad! reguards dick t.
Thanks everyone...Have a new coil on order..will post again with results.
Steve G |
#9 | |
#10 | |
Hm, going thru pretty much same 'electronic dist' Mallory dilema now! Mabe something that I've found can/will help you,eh !First, could you say whether YOU installed the elect Mallory system? And, can you give the model/series # of your distributor (i.e-50,etc)? And, does your current system have the box that I've pictured below? Anyway...I've found that that box is NO longer used/made. I was told by Mallory to take it out of my system(# series 50 elect dist). Check..if you have a LOOSE/defective ground, which is a common source of problem. Have you checked the magnetic pickup gap (.007/.010) ...too much gap=hard start ? Are you using carbon wires? Are you using resistor(12V). I have NO condensors/points in my elect dist system..you? Etc..etc... BTW- I like this elect stuff..if it works/reliable. But, as I'm not a diagnostician and do not like over the road breakdowns where I have ZERO change to fix on the road, I'm going back to what I know(somewhat )..i.e.- original equipment. Please let us know what you find to solve you elect dist system problem..if any. It may help some here. Good luck.BTW- beware of some advice. For example, I was told that my elect mallory crab can be converted back to ...like original equipment. Someone here , who is recognized at authority...said NO! Bummer for me. Cause the elect dist is expensive ..repair parts..as well as being PIA, IMO Last edited by hardtimes; 08-25-2012 at 02:59 PM. Reason: ... |
Yes same dist and same box.. will have new coil Tuesday, will report if a fix. Thanks Steve G
#12 | |
I'm taking my series 50 dist out today. Can you / anybody say if there is a 'bench test' way to tell is module/trigger are good/bad ![]() I'm anxious to see what you've found as a problem and fix ![]() BTW- Mallory guy was helpful...from a distance,eh! I was told...'get rid of the generator and run an alternator' ! Heck, don't know why the change would help? And, don't know why whoever put this system into this car....didn't put in an alternator in the first place (mabe wasn't told??). Are you running an alternator? |
#13 | |
The car would crackle and miss at top of RPM range especially when warm. I just bought a reproduction condenser and installed..I planned on pulling the distributor which I previously "rebuilt"...car runs great now!..so will forego pulling the distributor. It will be interesting to see if my plugs burn cleaner assuming my spark has improved...they fouled easily. Not pleased with the way the condenser fits (bracket reversed 180) but after a year of tuning carbs, dist etc......I'm pleased.. Lane |
