Old 04-24-2012, 12:03 PM   #1
Bob C
Default What Year?
Coupe on Epay looks like part 28-29 and part 30-31.
http://cgi.ebay.com/ebaymotors/Ford-...af0e1963#v4-50
Bob
Old 04-24-2012, 12:05 PM   #2
CarlG
CarlG's Avatar
Default Re: What Year?
And part something else???
Old 04-24-2012, 12:24 PM   #3
Purdy Swoft
Purdy Swoft's Avatar
It looks like a 29 standard coupe with 30-31 19 inch wheels, 31 radiator, 30-31 style steering wheel and probably later two tooth steering column and some other brand headlamps. Its not that unusual to find them with a mix of parts. In days past some were more interested in being able to ride than haveing the correct parts.
Old 04-24-2012, 01:01 PM   #4
Bob C
Something doesn't look right between the door and the back part of the body, look how
the top of the door lines up with the back part of the roof.
Bob
Old 04-24-2012, 02:27 PM   #5
Jim Parker Toronto
Jim Parker Toronto's Avatar
That's an authentic original "Johnny Cash" car, one piece at a time....
Jim Parker Toronto is offline   Reply With Quote
Old 04-24-2012, 02:44 PM   #6
wrndln
It is a late 29 standard coupe with a number of 30/31 parts like Purdy stated. It appears the drivers side door is drooping some. It would take a lot to restore it, I my opinion. Lots of parts to buy if it is to be made like it was originally.
Rusty Nelson
Old 04-24-2012, 03:22 PM   #7
Purdy Swoft
Bob
I think that they shimmed the front of the cowl in an attempt to allow for the taller 31 radiator. Shimming the front of the cowl will kick the back of the door down. If the whole body had been shimmed it would have looked better. Door alignment is mostly controlled by shimming the body.
The doors have the correct molding for a 28-29 coupe & tudor. the quarters and top appear correct for a 28-29 standard coupe. the rear bumper appears correct. The main things that stand out is the wheels, radiator and the steering.
Old 04-24-2012, 04:05 PM   #8
Farrell In Vancouver
Farrell In Vancouver's Avatar
These and the fact it's as pink as a Mary Kay Caddy!
Farrell In Vancouver is offline   Reply With Quote
Old 04-24-2012, 04:11 PM   #9
Steve Wastler
Steve Wastler's Avatar
It appears to have the correct hood and it is sitting low on the shroud, I dont think it is shimming of the cowl, maybe an issue with rotted roof wood causing the rear of the door to sag, but also appears the drivers qaurter to be up in the front. What ever all the issues it sure as heck aint worth the 6k bin
Steve Wastler is offline   Reply With Quote
Old 04-26-2012, 04:58 PM   #10
29restorod
29restorod's Avatar
If you buy it,I will give you $10. for those nasty old guide lights.
If you think SBC's are "Old School" you are not old enough.
29restorod is offline   Reply With Quote
Old 04-26-2012, 05:49 PM   #11
theHIGHLANDER
I'll give ya $40.00...
theHIGHLANDER is offline   Reply With Quote
Old 04-26-2012, 05:53 PM   #12
Kevin - Illinois
Kevin - Illinois's Avatar
I can hear Dad now..."close the door Kevin"...
Kevin - Illinois is offline   Reply With Quote
