Old 03-30-2012, 05:15 AM   #41
Reds
Default Re: Erratic problem
I will look at the carb Sat. morning.
Reds is offline   Reply With Quote
Old 03-30-2012, 07:24 AM   #42
G.M.
Pull the 2 front spark plugs out and see how they look.A lot of black soot means to rich. On a steel intake the drivers side main jet feeds # 1 on the passenger side. # 5 on the drivers side is feed by the main jet on the passenger side. On an aluminum intake # 1 is feed from passenger side main and # 5 from drivers side main. I would also get a set of NGK plugs. G.M.
www.fordcollector.com
Old 03-30-2012, 09:09 AM   #43
Displayman
Displayman's Avatar
I had similar problem.
Turned out to be a flat lobe on my cam,
mechanical pump was not working properly because of flat lobe.
Went to electric fuel pump. No more problems.
Just a thought.
Good luck!
Bob-Hampshire, Ill.
Displayman is offline   Reply With Quote
Old 12-04-2012, 06:25 PM   #44
Reds
I have just fixed my problem. I apologize for dragging this issue out for so long. After trying everything I could think of and swapping out every part (carb & ignition parts) and it still kept coming back. I had a spark plug wire that was only arcing occasionally. Maybe when I hit a bump or something it moved and arced? But I was looking at it in the dark and I saw a dull flash underneath a wire. But it only did it once or twice. When the problem popped up again I shut it down until dark and looked at it. A wire was sagging and would arc to the stud that the condensor attaches to. I put in all new plug wires and routed them differently. Still had the problem with it missing, but the wire was not arcing anymore. It turns out that I must have fried the condensor or coil whenever the erratic problem surfaced. I swapped out both after putting in new wires and it runs like a champ. The bad wire was only arcing once in a while and not every time it fired. Very strange and hard to find a problem that's not always there. I have changed the condensor and coil 3 times and the problem came back - probably due to wire arcing to the condensor/coil wire. Thanks to everyone on the forum that has offered advice and encouragement.
Old 12-04-2012, 08:21 PM   #45
40cpe
40cpe's Avatar
good on you for not giving up on it. I hope your health is improving.
Old 12-04-2012, 08:46 PM   #46
woodypecker
woodypecker's Avatar
Pat yourself on the back succesful medical treatment followed by succesful engine repair.
woodypecker is offline   Reply With Quote
