Old 06-19-2010, 03:12 PM   #1
firerod
Default Leaking oil return tube
What's the secret to sealing a oil return tube? Can't get mine to stop seeping. I am using new cork gaskets and copper washers.
firerod is offline   Reply With Quote
Old 06-19-2010, 03:35 PM   #2
Flathead
Flathead's Avatar
Default Re: Leaking oil return tube
Could it be leaking where the tube joins the dome shape end cap? I think the seam is soldered or brazed, might be a split there.
Flathead is offline   Reply With Quote
Old 06-19-2010, 03:51 PM   #3
V4F
V4F's Avatar
exactly wear is the leak ? the tube goes in the pan . hmmmmm .. steve
V4f
V4F is offline   Reply With Quote
Old 06-19-2010, 04:05 PM   #4
Bobster
Bobster's Avatar
I had the same problem and tried the cork / copper gasket approach to seal the leak. Still leaked at the lower end. Black silicone solved the problem. Not Henry Ford, but it works for me. BW
BW in WV
Bobster is offline   Reply With Quote
Old 06-19-2010, 04:28 PM   #5
firerod
Mine is leaking on the top side where the cork gasket is.
Old 06-19-2010, 05:05 PM   #6
Aerocraft
Aerocraft's Avatar
I have found the valve cover casting cracked in that area both at the top and/or bottom. Gar Williams
Aerocraft is offline   Reply With Quote
Old 06-19-2010, 07:22 PM   #7
V4F
V4F's Avatar
are you sure its the pan ?? wash clean , start motor & watch it untill the leak shows up ............. steve
V4f
