I wanted to put out a feeler (your opinions) on a few items I am looking into for rebuilding my Model A engine. Specifically the crankshaft and the pistons. For the pistons I could go with Snyder's or an aftermarket like Egge. For the crankshaft I was given the option to either counterbalance my current one or get a new counterbalanced one.
My use case is my Coupe. Rebuilt about 50 years ago and current sitting at .030 over bore. I drive it seldomly, but most of my driving is done between 35 and 50-55 mph. My price cap for my rebuild would be prohibit me from getting a Burtz long block built by someone (going price is ~$9500 w/o shipping) so please don't suggest this.
Feb '31 Standard Coupe Member of the Little Rhody Model A Club & MARC |
Hello, not so much about part selection, but trying to find an engine rebuilder willing to work on older engines. Tryed to use two different rebuilders, on two different projects, a 912 Porsche, and 1949 Buick, neither were in any hurry and neither would read any of the manuals I sent them. In case of the 912 , they cracked the 3rd piece of the engine and faced off the flywheel, without maintaining the distance to clutch pressure plate, had to take engine back out and have the mount area faced .Still waiting on the 49 Buick head . Attempt to find someone that can personally recommend a machine shop if that work is needed. Only seen to want to work on Chevy big blocks.
Does your engine need a full rebuild or maybe just a ring and valve job with adjusting the bearing clearances?
The bearing clearances will be the tricky part. You have to match the existing bearings to the crank and the crank pins to the pistons. If the existing bearings are worn unevenly or too far, putting a new crank in there could be a waste of (a lot of) money.
I was torn with just doing a valve job and a rebuild (extreme, I know) but I keep blowing head gaskets and exhaust gaskets. The real problem is that the block is not straight and needs to be resurfaced after a few overheating events. I figure if I have to take everything apart and put it back together again I may as well rebuild it, even if it doesn't burn any oil and has low mileage.
The rebuilders I talked to all have worked with Model A engines and are willing to take my engine.
A previous engine had welded on counterweights. Worked well and no indication of cracks or otherwise failing. Of course you have to get it straightened and balanced after welding on the weights.
#8 | |
But if you are going to the extent of replacing babbet with inserts, then I'd be inclined to balance your existing crank. The cost of a new balanced crankshaft will put you into Burtz territory compared with balancing the old one. Obviously there are other considerations, like the condition of the main and rod journals. But you can't make any meaningful decisions until teardown and you can see just what you have. Starting out with a 0.030" over block is not really a deal-breaker as long as it's otherwise sound.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
There are so many engine rebuilding options out there that this thread is like asking how long is a piece of string. I will assume you are using Babbitt bearings. Others have already mentioned you should mic everything after disassembly, then decide. Maybe you can get away with adjusting the bearings, a set of rings and a valve grind. If you only use the car rarely, that should do for a long time. Adding counterweights and a harmonic balancer will add life to any Model A engine but they all cost $.
How deep is your pocket?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
maybe in todays world there is too much information out there? (and a lot of us don't know what to use out of it) KISS
if the car is used just for short runs and icecream i would do the minimum amount required. no need to build a bullet proof engine. especially if the car is running ok now. maybe you can -shim the bearings -de-glace the cyls -new rings -lap the valves -check and replace only stuff that needs replacing. as far as machining always make sure the head and deck are flat and maybe magniflux the crank. do a basic farm rebuild. save you money for date night.
old ugly my mom would have told me. "these things are here to test us" |
I don't drive more than 800 miles a year so really not an engine I would put miles on. I am assuming it has Babbitt bearings. I will take the suggestion and do a partial disassembly and see what I find. Hopefully nothing much so I can save up for someone/something special
![]() I'll create another post if I have any questions. Thank you for the advice!
#12 | |
#13 |
Watch marketplace for a running driving chassis where a hot rodder has removed the body. Usually cost $1,500-$3,500 or check with some rebuilders for a short block that wasn't paid for.
#14 |
Fresh engine paint always helps.
#15 |
I love it when i can do one of those rebuilds.
