Old 06-04-2026, 12:17 PM   #1
Mike1291
Mike1291's Avatar
Default Part Selection for Rebuild
I wanted to put out a feeler (your opinions) on a few items I am looking into for rebuilding my Model A engine. Specifically the crankshaft and the pistons. For the pistons I could go with Snyder's or an aftermarket like Egge. For the crankshaft I was given the option to either counterbalance my current one or get a new counterbalanced one.
My use case is my Coupe. Rebuilt about 50 years ago and current sitting at .030 over bore. I drive it seldomly, but most of my driving is done between 35 and 50-55 mph.
My price cap for my rebuild would be prohibit me from getting a Burtz long block built by someone (going price is ~$9500 w/o shipping) so please don't suggest this.
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 06-04-2026, 01:02 PM   #2
gdmn852
gdmn852's Avatar
Default Re: Part Selection for Rebuild
Hello, not so much about part selection, but trying to find an engine rebuilder willing to work on older engines. Tryed to use two different rebuilders, on two different projects, a 912 Porsche, and 1949 Buick, neither were in any hurry and neither would read any of the manuals I sent them. In case of the 912 , they cracked the 3rd piece of the engine and faced off the flywheel, without maintaining the distance to clutch pressure plate, had to take engine back out and have the mount area faced .Still waiting on the 49 Buick head . Attempt to find someone that can personally recommend a machine shop if that work is needed. Only seen to want to work on Chevy big blocks.
gdmn852 is offline   Reply With Quote
Old 06-04-2026, 02:06 PM   #3
J Franklin
J Franklin's Avatar
Does your engine need a full rebuild or maybe just a ring and valve job with adjusting the bearing clearances?
Old 06-04-2026, 02:32 PM   #4
alexiskai
alexiskai's Avatar
The bearing clearances will be the tricky part. You have to match the existing bearings to the crank and the crank pins to the pistons. If the existing bearings are worn unevenly or too far, putting a new crank in there could be a waste of (a lot of) money.
Old 06-04-2026, 02:37 PM   #5
Mike1291
Mike1291's Avatar
I was torn with just doing a valve job and a rebuild (extreme, I know) but I keep blowing head gaskets and exhaust gaskets. The real problem is that the block is not straight and needs to be resurfaced after a few overheating events. I figure if I have to take everything apart and put it back together again I may as well rebuild it, even if it doesn't burn any oil and has low mileage.
The rebuilders I talked to all have worked with Model A engines and are willing to take my engine.
Old 06-04-2026, 04:20 PM   #6
J Franklin
J Franklin's Avatar
You might just need a quote on the work that needs to be done to keep gaskets from blowing. The shop can dissasemble whatever is needed to do the job.
Old 06-04-2026, 04:41 PM   #7
nkaminar
nkaminar's Avatar
A previous engine had welded on counterweights. Worked well and no indication of cracks or otherwise failing. Of course you have to get it straightened and balanced after welding on the weights.
Old 06-04-2026, 04:42 PM   #8
JayJay
Before thinking about new pistons, I'd take the engine apart and thoroughly mic it. It might be that your cylinders are OK and you won't need new pistons. I did a "refurbish" on an engine a couple of years ago, valve job, new rings, new camshaft, new lifters, but the bearings were OK so I just reshimmed. It's worked out fine. If the babbet is OK, the bearings clearance out OK, and you will reuse the babbet then don't even think of a new crank, balance the old one if you wish but babbet bearings MUST be fitted exactly to the crankshaft, so a new crankshaft would require replacing the main bearings at a minimum, and likely the connecting rods as well.
But if you are going to the extent of replacing babbet with inserts, then I'd be inclined to balance your existing crank. The cost of a new balanced crankshaft will put you into Burtz territory compared with balancing the old one.
Obviously there are other considerations, like the condition of the main and rod journals. But you can't make any meaningful decisions until teardown and you can see just what you have. Starting out with a 0.030" over block is not really a deal-breaker as long as it's otherwise sound.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-04-2026, 05:09 PM   #9
Synchro909
Synchro909's Avatar
There are so many engine rebuilding options out there that this thread is like asking how long is a piece of string. I will assume you are using Babbitt bearings. Others have already mentioned you should mic everything after disassembly, then decide. Maybe you can get away with adjusting the bearings, a set of rings and a valve grind. If you only use the car rarely, that should do for a long time. Adding counterweights and a harmonic balancer will add life to any Model A engine but they all cost $.
How deep is your pocket?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 06-04-2026, 07:12 PM   #10
old ugly
old ugly's Avatar
maybe in todays world there is too much information out there? (and a lot of us don't know what to use out of it) KISS
if the car is used just for short runs and icecream i would do the minimum amount required. no need to build a bullet proof engine. especially if the car is running ok now.
maybe you can
-shim the bearings
-de-glace the cyls
-new rings
-lap the valves
-check and replace only stuff that needs replacing.
as far as machining always make sure the head and deck are flat and maybe magniflux the crank.
do a basic farm rebuild.
save you money for date night.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is online now   Reply With Quote
Old 06-04-2026, 10:06 PM   #11
Mike1291
Mike1291's Avatar
I don't drive more than 800 miles a year so really not an engine I would put miles on. I am assuming it has Babbitt bearings. I will take the suggestion and do a partial disassembly and see what I find. Hopefully nothing much so I can save up for someone/something special
I'll create another post if I have any questions. Thank you for the advice!
Old 06-05-2026, 04:37 AM   #12
Bruce of MN
Bruce of MN's Avatar
maybe you can
-shim the bearings
-de-glace the cyls
-new rings
-lap the valves
I did that and it ran fine for 15+ years.
Old 06-05-2026, 05:48 AM   #13
Wick
Wick's Avatar
Watch marketplace for a running driving chassis where a hot rodder has removed the body. Usually cost $1,500-$3,500 or check with some rebuilders for a short block that wasn't paid for.
Wick is offline   Reply With Quote
Old 06-05-2026, 06:18 AM   #14
nkaminar
nkaminar's Avatar
Fresh engine paint always helps.
Old 06-05-2026, 09:37 AM   #15
old ugly
old ugly's Avatar
I love it when i can do one of those rebuilds.
old ugly
