Old 06-04-2026, 12:42 PM   #1
Old Henry
Old Henry's Avatar
Default Valve stem size??
What is the correct valve stem size for the 600-16 inner tubes for my 47 sedan?
I just bought the only tubes Summit Racing sells and the valve stems were TR13 size, too little for the hole in my rims. I've bought tubes with the correct size years ago but forget the size.
Also, where else can I look for them?
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 06-04-2026, 12:46 PM   #2
Old Henry
Old Henry's Avatar
Default Re: Valve stem size??
I think I found the first answer.
Is it TR 15?
Still trying to find them.
Old 06-04-2026, 12:51 PM   #3
Old Henry
Old Henry's Avatar
Found the source:
https://aztirewarehouse.com/products...RoCTyoQAvD_BwE
Old 06-04-2026, 01:02 PM   #4
Old Henry
Old Henry's Avatar
Woah!
Don't buy from AzTireWarehouse. Shipping was $134.00 for 4 inner tubes!!
I found them other places. Bought them on ebay.
Old 06-04-2026, 01:02 PM   #5
tubman
tubman's Avatar
Another positive aspect of "Old Henry". Not only does he take entertaining trips, but he solves his own problems.
Old 06-04-2026, 02:24 PM   #6
cas3
Last tubes I got from Coker had some plastic bushings to make up for the size difference.
Not ideal, but worked
cas3 is online now   Reply With Quote
Old 06-04-2026, 02:47 PM   #7
Bob C
I was thinking bushings also.
Old 06-04-2026, 04:23 PM   #8
J Franklin
J Franklin's Avatar
Or you could use O-rings.
Old 06-04-2026, 04:39 PM   #9
flatford8
flatford8's Avatar
Glad you found your solution!….there are bushings that can be used like Skip said….you can also try millertire.com. They specialize in early vehicles and trucks..…..Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 06-05-2026, 08:54 AM   #10
GaryU.
GaryU.'s Avatar
Found some on Amazon years ago, don't know if they're still available.
GaryU. is offline   Reply With Quote
