Is it worthwhile to install a distributor heat shield?
Never ran one, five on the shelf.
I don't like the way they mount, under the two head nuts. The nuts don't make full contact with the head.
Waste of money!!!!
Someone thought they could see a chance to make some $.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
I would first consider flushing my cooling system a few times and possibly installing a 6 blade fan before installing the distributor heat shield. |
i like the look of it, so no waste of money…
i have no idea if they do any good.
i had one years back, i did not see any advantage to using it and i would not buy one. The one thing i did not like about it, when it came to pulling the distributor out it had to come off to access the dist hold down screw so i never put it back on.
old ugly my mom would have told me. "these things are here to test us" |
They block the distributor set screw. They require loosening of head nuts to remove. And their entire purpose is to protect a condenser design that's no longer in use (modern condensers are heat-resistant). No reason to use.
[QUOTE=Fred Ryan;2453955]Is No!
www.whidbeymodelaclub.com |
In the old days, when condensers failed from radiated heat, the heat shield had a purpose. Today the heat shield is an unnecessary decoration because condensers are superior and withstand the heat.
Bob Bidonde |
All of the above prior comments:ditto
Experience has shown that the shield radiates heat up from the head towards the condenser. If concern about condenser issues, mount the condenser up by the coil. |
#13 |
I carry my spare condenser attached to the coil mounting bracket so that if I need it, I simply disconnect the one in the distributer and connect it - done!
#14 |
Never worked for me.
