Old 06-02-2026, 01:35 AM   #21
German guy
German guy's Avatar
Default Re: Stalling at stop sign
Try a few easy fixes first.
I have never been a believer in anything that I could pour into a car having any real effectiveness...BUT...I had stalling on stops a few months ago and tried pouring a fuel system and valve cleaner into the half full gas tank. The problem stopped after driving about 25 miles and has not come back.
German guy is offline   Reply With Quote
Old 06-02-2026, 07:56 AM   #22
Steve_Mack_CT
Steve_Mack_CT's Avatar
I also posted about this issue a couple months back and realized I said I would give an update. It's fixed. Two - maybe 3 factors in play to fix the issue.
1. Engine has a hi comp head, B cam & 0.100 overbore. May want a slightly richer mix in general, but not a huge difference.
2. Float needed adjusting. Changed out float valve as well just in case.
3. Self inflicted - I miss-adjusted idle earlier making problem worse. Despite this being our third Model A in the past 25 years or so, idle adjustment on our other prewar cars - heck most anything idle adjustment I have done before are opposite. Sharing in case others do the same thing.
Car idles well and level or bottom of a hill stops ⁶don't present any issues. Now on to the next thing!
Steve
Current:
1931 Model A Deluxe Roadster
Steve_Mack_CT is offline   Reply With Quote
Old 06-03-2026, 05:53 AM   #23
32Ford13
I knew I didn’t have a vacuum leak. My stalling was cured by turning the air screw in on the carb. I did a little at a time and found a sweet spot. Had to tweek on the idle speed at the same time. Problem solved.
32Ford13 is offline   Reply With Quote
