Old 06-01-2026, 07:25 PM   #1
Fred Ryan
Default Distributor Heat Shield
Is it worthwhile to install a distributor heat shield?
Fred Ryan is offline   Reply With Quote
Old 06-01-2026, 07:45 PM   #2
Bigsnapper43
Default Re: Distributor Heat Shield
Never ran one, five on the shelf.
Bigsnapper43 is offline   Reply With Quote
Old 06-01-2026, 07:53 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
I don't like the way they mount, under the two head nuts. The nuts don't make full contact with the head.
Old 06-01-2026, 07:57 PM   #4
doa44green
Waste of money!!!!
doa44green is offline   Reply With Quote
Old 06-01-2026, 10:27 PM   #5
Synchro909
Synchro909's Avatar
Someone thought they could see a chance to make some $.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 06-02-2026, 01:23 AM   #6
German guy
German guy's Avatar
How hot does your engine tend to get? After an hour of driving at moderate speeds in 85+ F heat I can tap the head without it burning....the engine never seems to cast off a lot of heat when I stop and open the hood. That said..I do not have an inline temp gauge so I do not know what the exact temp is. The side vents tend to dissipate a great deal of heat, and the standard fans are very effective. I have read that some drive at slow speeds in long parades at high outside temps and experience overheating...but it does not seem to be a common problem in normal use.
I would first consider flushing my cooling system a few times and possibly installing a 6 blade fan before installing the distributor heat shield.
German guy is offline   Reply With Quote
Old 06-02-2026, 07:05 AM   #7
TomInCologne
TomInCologne's Avatar
i like the look of it, so no waste of money…
TomInCologne is offline   Reply With Quote
Old 06-02-2026, 09:19 AM   #8
old ugly
old ugly's Avatar
i have no idea if they do any good.
i had one years back, i did not see any advantage to using it and i would not buy one.
The one thing i did not like about it, when it came to pulling the distributor out it had to come off to access the dist hold down screw so i never put it back on.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 06-02-2026, 10:37 AM   #9
alexiskai
alexiskai's Avatar
They block the distributor set screw. They require loosening of head nuts to remove. And their entire purpose is to protect a condenser design that's no longer in use (modern condensers are heat-resistant). No reason to use.
Old 06-02-2026, 10:51 AM   #10
Gary WA
Gary WA's Avatar
[QUOTE=Fred Ryan;2453955]Is No!
www.whidbeymodelaclub.com
Old 06-02-2026, 11:42 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
In the old days, when condensers failed from radiated heat, the heat shield had a purpose. Today the heat shield is an unnecessary decoration because condensers are superior and withstand the heat.
Bob Bidonde
Old 06-02-2026, 02:30 PM   #12
duke36
All of the above prior comments:ditto
Experience has shown that the shield radiates heat up from the head towards the condenser. If concern about condenser issues, mount the condenser up by the coil.
Old 06-02-2026, 07:01 PM   #13
Synchro909
Synchro909's Avatar
I carry my spare condenser attached to the coil mounting bracket so that if I need it, I simply disconnect the one in the distributer and connect it - done!
Old 06-02-2026, 08:48 PM   #14
wwirz
Never worked for me.
wwirz is offline   Reply With Quote
