I followed Paul Shinn's video about installing a cell phone charger using a unit from Amazon https://www.amazon.com/dp/B0D4YSHSH3...sin_title&th=1. It is described as a 12V cigarette lighter and power outlet, and says it comes with a 10 amp fuse, but this is the one that came with it. As nearly as I can decipher this is a 3 amp fuse. The symbol before the numeral 3 appears to be something that didn't stamp completely in the factory, but that is what it looks like. I have this connected to the ammeter and grounded in common with the turn signals. I am using red for power--neg, and black for ground--pos. Paul's video shows an in line fuse, but he doesn't state its size. I can splice in a different fuse holder, but what size should I use?
Shouldn't need too high of an amp rating. I would start out low and increase the size if your charger blows the fuse. I have a 5amp fuse in mine (#5 on fuse box) and also run my Garmin GPS.
It is a 3 amp, fast blow, 250 volt fuse. Try it but if it blows, look for a 5 amp and 8 amp fuse of the same size. Then try the 5 amp and if that blows the 8 amp.
Some cell phone chargers consume as much as 10watts during charging. This means the maximum amperage during charging is A = 10W/12v = .83amps for 6volts = 1.7 amps.
Just looked t my phone,it says it was last charged on Friday night,and has 70% remaining right now.But,I don't type on my phone and I don't talk on my computer.Two different appliances to me.
Consider how you may be using the socket and use common sense.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
Assuming standard positive ground system, attach red (positive) to ground and black (negative) to battery.
3 amps is for 12V supply, may need to use 5 amp fuse for six volts. I haven't seen Paul's video, but I assume also your mount isolates the socket housing from vehicle ground, otherwise it will blow any fuse. |
I believe the mount is adequately isolated. It is all plastic except for the socket itself. Will try a larger fuse. Re: change to 12V, if this were a daily driver, I might do it, but for a hobby car I would rather keep the 6V.
Here what I did, I bought a lighter charger from the Dollar store and took it apart. Connect the positive to ground and negative to batt power, an inline fuse for safety, mount it to a piece of plastic and mount it somewhere on bottom edge of dash.
Amazon has a bunch of choices. I got one that has a cigar lighter socket and 2 USB jacks. Install a fuse and an on/off switch because mine draws current all the time even when nothing is plugged in!
