Old 05-25-2026, 02:13 PM   #1
Russell Reay
Russell Reay's Avatar
Default Cell phone charging
I followed Paul Shinn's video about installing a cell phone charger using a unit from Amazon https://www.amazon.com/dp/B0D4YSHSH3...sin_title&th=1. It is described as a 12V cigarette lighter and power outlet, and says it comes with a 10 amp fuse, but this is the one that came with it. As nearly as I can decipher this is a 3 amp fuse. The symbol before the numeral 3 appears to be something that didn't stamp completely in the factory, but that is what it looks like. I have this connected to the ammeter and grounded in common with the turn signals. I am using red for power--neg, and black for ground--pos. Paul's video shows an in line fuse, but he doesn't state its size. I can splice in a different fuse holder, but what size should I use?
Russell Reay is offline   Reply With Quote
Old 05-25-2026, 04:32 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Cell phone charging
Shouldn't need too high of an amp rating. I would start out low and increase the size if your charger blows the fuse. I have a 5amp fuse in mine (#5 on fuse box) and also run my Garmin GPS.
Old 05-25-2026, 05:11 PM   #3
nkaminar
nkaminar's Avatar
It is a 3 amp, fast blow, 250 volt fuse. Try it but if it blows, look for a 5 amp and 8 amp fuse of the same size. Then try the 5 amp and if that blows the 8 amp.
Old 05-25-2026, 08:01 PM   #4
CT Jack
CT Jack's Avatar
Some cell phone chargers consume as much as 10watts during charging. This means the maximum amperage during charging is A = 10W/12v = .83amps for 6volts = 1.7 amps.
CT Jack is offline   Reply With Quote
Old 05-25-2026, 08:42 PM   #5
Keith True
Keith True's Avatar
Just looked t my phone,it says it was last charged on Friday night,and has 70% remaining right now.But,I don't type on my phone and I don't talk on my computer.Two different appliances to me.
Old 05-25-2026, 09:20 PM   #6
Synchro909
Synchro909's Avatar
As I have posted a number of times, my cars are drivers. Without wanting to be critical of those chasing points, I see no reason to not convert to 12v. I suspect this car is already on 12 volts. If so, I'd install the socket with a 3 amp fuse and call it DONE. As others have said, if you blow the fuse, simply use a bigger one. A couple of my cars have 2 or 3 of these sockets for a refrigerators, GPS, Phone etc. I use a plug with 2 USB sockets built in so I have a bigger than 3 amp fuse.
Consider how you may be using the socket and use common sense.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 05-26-2026, 07:12 AM   #7
Badpuppy
Assuming standard positive ground system, attach red (positive) to ground and black (negative) to battery.
3 amps is for 12V supply, may need to use 5 amp fuse for six volts.
I haven't seen Paul's video, but I assume also your mount isolates the socket housing from vehicle ground, otherwise it will blow any fuse.
Old 05-26-2026, 09:12 AM   #8
Russell Reay
I believe the mount is adequately isolated. It is all plastic except for the socket itself. Will try a larger fuse. Re: change to 12V, if this were a daily driver, I might do it, but for a hobby car I would rather keep the 6V.
Old 05-26-2026, 11:03 AM   #9
corvette8n
corvette8n's Avatar
Here what I did, I bought a lighter charger from the Dollar store and took it apart. Connect the positive to ground and negative to batt power, an inline fuse for safety, mount it to a piece of plastic and mount it somewhere on bottom edge of dash.
Old 05-26-2026, 11:49 AM   #10
Herb Concord Ca
Amazon has a bunch of choices. I got one that has a cigar lighter socket and 2 USB jacks. Install a fuse and an on/off switch because mine draws current all the time even when nothing is plugged in!
Herb Concord Ca is offline   Reply With Quote
