Old 05-13-2026, 05:52 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default 33-34 Fuel line routing
Working on a 33 chassis. When the fuel line gets to the front does it go through the X member or turn up behind it and go to the firewall? Thanks
Old 05-13-2026, 06:13 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 33-34 Fuel line routing
Old 05-14-2026, 10:38 AM   #3
The Art Doctor
The Art Doctor's Avatar
Assuming a 33 is the same as a 34 it goes through the X member and then up onto the firewall.
The Art Doctor is offline   Reply With Quote
Old 05-14-2026, 10:44 AM   #4
petehoovie
petehoovie's Avatar
Old 05-15-2026, 09:13 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
What the Art Doctor shows is how my 34 was when I originally built it. Very similar routing as a 32 has.
Old 05-16-2026, 08:50 PM   #6
v8fordman
v8fordman's Avatar
I thought that ‘32-‘35’s used a siamese style gas line with the small side going from the fuel sending unit to the gauge. I’m not seeing that in the pictures.
v8fordman is offline   Reply With Quote
Old 05-17-2026, 01:20 PM   #7
Ken/Alabama
They do. The project I’m working on will be using an electric gauge so I’m using just the 1/4” copper plated steel fuel line .
Old 05-18-2026, 11:42 AM   #8
The Art Doctor
That little pipe was cut off of mine where it exited the firewall and removed the whole way back to the tank before I got it. The extra black wire you see is the lead from the sending unit to the '36 truck electronic gauge I am using.
