#21 | |
The problem I have experienced over and over is that the average Model A driver with the average original engine advances the spark too much on the 6.0 head and the engine knocks. The driver can't hear it knocking (for various reasons, including old age loss of hearing) and they pound the babbitt out in a short time. Many drivers start the engine, then pull the timing lever down all the way and leave it there all the time. You can explain to them all you want about what they need to do with the timing, but they just pull it all the way down. The stock cylinder head is low enough compression that it is very forgiving to this sort of behaviour. With the 6.0 head and an engine that is timed to TDC like Henry called for, that engine won't last long. So I mainly recommend the 5.5 head to save the driver from themselves. You get a little performance boost but less risk of hurting the engine.
Jim Cannon Former MAFCA Technical Director ![]() "Have a Model A day!" |
#22 | |
If someone does have the skills to manage spark timing, I would actually say I think the Burtz head is the best option. Not because it has the highest compression, but because they changed the design of the water jacket. The Burtz head blocks the large central return vent in the stock head, which forces more coolant toward the rear cylinders. These cylinders run hotter in stock configurations and are more prone to gasket failure, valve failure, etc. Getting more cooling to them is an investment in the lifespan of the engine – provided that you don't undermine it by over-advancing the spark, that is. |
#23 |
Are the high compression heads marked in any way indicating what head/compression ratio it is?
#24 |
Typically they are attempting to "pass" as stock heads, so with a couple of exceptions, the only way to know is to examine the shape and size of the combustion chamber.
#25 |
I would think that they could be discretely stamped with a 5.5 or a 6.0. I would not think that there would be enough difference between the two combustion chambers to determine what it is.
#26 |
#27 | |
FordGarage has a page that shows some older heads. |
#28 | |
![]() I can't tell you about any others. Last edited by Y-Blockhead; 05-07-2026 at 05:25 PM. |
#29 |
B Butturff, To tell what kind of bearing you have without opening up the engine, you can use a bore scope and insert it into the hole after you take the breather tube out. The poured bearing at the rear has a large poured flange at the forward end that is used as a thrust bearing.
The 6.0 head puts out slightly more torque and horsepower than the 5.5 head, which may be because of better breathing rather than the higher compression ratio. In my opinion the hart shaped combustion chambers do not breath as well as other designs. See https://www.snydersantiqueauto.com/c...%20release.pdf
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 05-07-2026 at 05:03 PM. |
#30 | |
Neil, thanks for this tip! I've never read or heard of this before and will do it very soon.
_______________________ The other Bruce in Minnesota 1931 Model A Closed Cab (Budd) Pickup "Aurora" Model A Ford Club of America Lady Slipper A's "You can't go back and change the beginning, but you can start where you are and change the ending." - C.S. Lewis |
#31 | |
#32 | |
Thank you too. The brass should be readily apparent with the illumination from my bore scope.
