Old 05-06-2026, 04:22 PM   #1
BButturff
BButturff's Avatar
Default New 5.5:1 Cylinder Head Availability
When I bought my Model A eighteen months ago I had no idea what cylinder head it had so I wasn't looking to buy one. But I remember them being readily available at Snyder's, Mike's, Bert's, Model A Medic, etc. So now that I know I have a stock head and I'm looking for a 5.5:1 head they've been "temporarily out of stock" for many months.
Anybody out there have an idea why this is? Are they no longer being produced?
_______________________
The other Bruce in Minnesota
1931 Model A Closed Cab (Budd) Pickup "Aurora"
Model A Ford Club of America
Lady Slipper A's
"You can't go back and change the beginning,
but you can start where you are and change
the ending." - C.S. Lewis
BButturff is online now   Reply With Quote
Old 05-06-2026, 04:28 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: New 5.5:1 Cylinder Head Availability
I see Snyder's has the 6.0 in stock. Maybe they are phasing out the 5.5 since they are almost the same CR and I believe made by the same person.
https://www.snydersantiqueauto.com/p...8622&cat=41686
Old 05-06-2026, 04:32 PM   #3
47topless
47topless's Avatar
Check with your favorite local machine shop and inquire as to having your head milled to your specifications.
47topless is offline   Reply With Quote
Old 05-06-2026, 04:37 PM   #4
Y-Blockhead
Not a good idea...
Old 05-06-2026, 04:49 PM   #5
Keith True
Keith True's Avatar
You can't mill an A head to gain anything.The high-compression head has a whole different combustion chamber design.Some call it a heart shaped design.I don't have any pictures,but folks on here have posted the stock and high compression designs side by side.
Old 05-06-2026, 05:08 PM   #6
BButturff
BButturff's Avatar
That's probably what's going on. I had the 5.5 head marked on my wish lists so wasn't looking for anything else. Thanks!
Lady Slipper A's
Old 05-06-2026, 06:11 PM   #7
47topless
47topless's Avatar
Good to know. I went the mill route with my V8 heads, and it worked great, but the A head is another animal. Thanks for the clarification.
Old 05-06-2026, 06:47 PM   #8
emf
emf's Avatar
If you have an interest in a high compression head, contact Terry Burtz since he has a very good one available and I believe they are in stock. burtzblock.com
Frank
emf is offline   Reply With Quote
Old 05-06-2026, 07:06 PM   #9
Synchro909
Synchro909's Avatar
If you were considering a 5.5:1 head, a 6:1 head will not be much different. You would have a little more grunt at the bottom end of the rev range but that is about it. Just make sure you reduce the amount of ignition advance - too much is what kills bearings (and other things in there)
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 05-06-2026, 08:12 PM   #10
Klattu1929
I put a Burtz head on and I am very impressed; my engine is .100 over. I also installed an automatic advance in the valve chamber. Limit my total advance to about 25-26 deg. engine runs great, plenty of power. Make sure your main and rod bearings are adjusted. I have a couple stock heads, and they are just dust collectors now.
Klattu1929 is offline   Reply With Quote
Old 05-06-2026, 10:34 PM   #11
Jim/GA
Jim/GA's Avatar
No. Snyder's makes both heads, they will keep selling both.
They make them in batches. You have to wait for the time for casting, transportation, machining, etc. They will be back in stock eventually.
I recommend the 5.5 over the 6.0 head for the average driver with average original engine. It is very easy to get engine knock with the 6.0 head, and then your bearings will go south.
Jim Cannon
"Have a Model A day!"
Old 05-07-2026, 06:50 AM   #12
BButturff
BButturff's Avatar
I have heard or read this exact thing before. Although my engine was rebuilt fairly recently I don't know if it still has babbitt bearings or if it has been converted to insert bearings. Unfortunately, the family of the previous owner was no help in answering this question. My engine starts, idles and runs very well so I'm not yet willing to open it up just to find out.
Lady Slipper A's
Old 05-07-2026, 07:03 AM   #13
alexiskai
alexiskai's Avatar
Why would that make a difference in this context?
Old 05-07-2026, 07:19 AM   #14
BButturff
BButturff's Avatar
Since there were valid suggestions of using a Snyder's 6.0 head or even the Burtz 6.5 head I felt compelled to explain why I don't consider them to be an option at this time. If and when I pull the pan off of my engine and discover insert bearings I would consider them.
Lady Slipper A's
Old 05-07-2026, 07:42 AM   #15
alexiskai
alexiskai's Avatar
The idea that Babbitt bearings can’t handle higher compression is a myth.
Old 05-07-2026, 08:06 AM   #16
BButturff
BButturff's Avatar
If it really is a myth I would appreciate any and all evidence to prove it so. Until then I can't take a chance on a Model A that I'll be handing down to my grandson some day.
Lady Slipper A's
Old 05-07-2026, 08:14 AM   #17
BButturff
BButturff's Avatar
Randall Strickland, you've poured your fair share of babbitt for T's and A's. What's your opinion about babbitt and higher compression?
Lady Slipper A's
Old 05-07-2026, 08:29 AM   #18
Big hammer
Babbitt can’t handle high compression ??? Tell that to diesel engines that have babbitt bearings ! way more compression than a measly little 6.0 6.5 7.0 compression
get a bigger hammer tap done
Old 05-07-2026, 09:29 AM   #19
Fullraceflathead
Fullraceflathead's Avatar
Some of the large diesels have babbitt bearings in them and they have compression ratios around 18.5-1!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 05-07-2026, 09:40 AM   #20
Bob Bidonde
Bob Bidonde's Avatar
I have been running 5.5:1 and 6:1 compression ratio cylinder heads for many years successfully with Babbitt bearings. By the way, the bearing diameter determines the amount of bearing stress in the Babbitt due to cylinder combustion pressures and inertial forces.
It makes good business sense if the 5.5:1 head was discontinued because of the 6:1 head. The difference between them is only 3%.
Bob Bidonde
