Old 05-06-2026, 01:14 PM   #1
atch
atch's Avatar
Default aluminum timing gear recommendation
I've found a couple of posts about timing gears but nowhere have I found a recommendation for who makes or where to buy the best aluminum Model A timing gear.
What say you? Is one better than another or are they all the same?
atch (Mike Atchley)
Columbia, Missouri
atch is online now   Reply With Quote
Old 05-06-2026, 02:04 PM   #2
Flathead
Flathead's Avatar
Default Re: aluminum timing gear recommendation
Snyder's has one, looks good.
Flathead is offline   Reply With Quote
Old 05-06-2026, 02:07 PM   #3
JayJay
Dan McEachern, hands down. [email protected], (510)532-8228
He also makes the timing gear in bronze, and steel crank gears. His gears are works of art.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 05-06-2026, 02:51 PM   #4
KMBeers
KMBeers's Avatar
I have used the Snyder’s aluminum gear with the stock crank gear in an engine and it worked well. Lots of folks have complained about the aluminum gear being “noisy” but I could not hear it over the noises in the car. Good luck with you project….
KMBeers is offline   Reply With Quote
Old 05-06-2026, 03:17 PM   #5
alexiskai
alexiskai's Avatar
There are clearly at least two "generic" manufacturers of aluminum timing gears in addition to McEachern. The Snyders gear looks different from the gear sold by, e.g., CW Moss. I find it hard to believe there's any functional difference between these three gears if they're all made to the same size spec. This isn't a jet turbine we're talking about.
Old 05-06-2026, 03:58 PM   #6
Werner
Werner's Avatar
Good evening Mike.
I have been running the aluminum camshaft gear from Don Snyder for 7,000 miles now. It works exactly as it should. Compared to the previous, worn Pertinax gear, I cannot detect any increase in noise levels.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 05-06-2026, 04:54 PM   #7
Jim Brierley
I too have heard complaints about aluminum being noisy always from guys that have never tried them! I've run them for over 60 years and have never had a noisy one! One had a casting flaw in the center of a tooth, I ran it for at least 20 tears, and it is still good!
Old 05-06-2026, 05:02 PM   #8
nkaminar
nkaminar's Avatar
Snyders. Many miles on mine. Cannot hear it. Of course I cannot hear a lot of things.
Old 05-06-2026, 06:21 PM   #9
Bob C
X2 I have one in my Burtz.
Old 05-06-2026, 07:03 PM   #10
atch
atch's Avatar
Thanks everyone.
I really appreciate your time, thoughts, and experience.
atch (Mike Atchley)
Columbia, Missouri
Old 05-07-2026, 07:01 PM   #11
Herb Concord Ca
Both of my aluminum gears came from Bert's. Neither make noise.
Herb Concord Ca is offline   Reply With Quote
Old 05-08-2026, 10:36 PM   #12
CWPASADENA
CWPASADENA's Avatar
I agree,
Dan makes the best gears. I have used lots of them.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-09-2026, 12:56 AM   #13
JayJay
Here is a set, installed. Pardon the goofy angle, the engine is on a stand.
JayJay
Old 05-09-2026, 09:38 PM   #14
atch
atch's Avatar
Someone today mentioned something that I'd like your collective opinions about. It was suggested that perhaps fiber timing gears are designed that way to fail before something else fails catastrophically. Or perhaps Henry just wanted to save a cent or two per car.
What say ye?
atch (Mike Atchley)
Columbia, Missouri
Old 05-10-2026, 11:32 AM   #15
Werner
Werner's Avatar
Guten Mittag Mike.
In this country, these "Novotex" spur gears were installed in four- and six-cylinder V-engines until mid-1985. The reason for this choice was smooth running, as the plastic gears operated against the steel crankshaft gear with a slight preload.
However, this solution was not considered ideal, as these camshaft gears would wear out after an average of 120,000 to 140,000 km in the six-cylinder models; in the four-cylinder models, due to the presence of an auxiliary balance shaft, they lasted only 80,000 km.
There were some experimental production runs utilizing lapped metal gears (steel, I believe?), but these produced a high-pitched singing at high RPM. This was deemed too intrusive for vehicles in the 6-cylinders luxury class.
The more comfortable solution was the toothed belt, though this, too, suffered from a poor service life.
In the case of the simple Model A, I suspect that the primary motivation was actually cost-saving rather than noise reduction. After all, as metal gears, they demand significantly higher manufacturing precision, furthermore, the lapping process, which required forced pairing, had to be performed largely by hand, piece by piece.
Werner
Citroen 11 CV, 1947
Old 05-10-2026, 12:08 PM   #16
alexiskai
alexiskai's Avatar
I recently read an SAE Transactions article about the ‘29 Chevy engine, which also used phenolic resin (“Celeron”) timing gears. The head of engineering for the project said that they decided to use Celeron gears because they found that, while the gears would wear down, they also appeared to expand by absorbing oil from the crankcase. He said the rate of wear and the rate of expansion balanced each other perfectly. I can try to find the article if people want to know more.
Old 05-10-2026, 08:13 PM   #17
ModelA29
ModelA29's Avatar
Originally Posted by alexiskai View Post
There are clearly at least two "generic" manufacturers of aluminum timing gears in addition to McEachern.... I find it hard to believe there's any functional difference between these three gears if they're all made to the same size spec.
The only difference may be in the material and heat treat - there are many grades of aluminum and levels of heat treat. I don't think anyone advertises those details.
ModelA29 is offline   Reply With Quote
Old 05-10-2026, 08:42 PM   #18
johnneilson
Materials, sure to be different, but Dan is a craftsman and that is reflected in finish and more importantly tolerances maintained.
I have stacks of metal gears, some are just better than others.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 05-10-2026, 09:52 PM   #19
Synchro909
Synchro909's Avatar
I have an aluminium timing gear in all of my cars with mileages ranging from 10,000 miles to about 80,000. If there is any noise coming from them, I can't hear it but my wife says I am deaf too!
I'm sure they all came from Snyders over a period of 20 years or more. That's good enough fr me.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 05-10-2026, 09:57 PM   #20
updraught
updraught's Avatar
Anyone know why Antique Engine Rebuilding would not use a metal gear?
updraught is offline   Reply With Quote
