Old 05-05-2026, 12:23 PM   #1
drumyn29
drumyn29's Avatar
Default $200 flathead
for the 30 hot rod
drumyn29 is offline   Reply With Quote
Old 05-05-2026, 01:07 PM   #2
drumyn29
drumyn29's Avatar
Default Re: $200 flathead
I'm definitely going to be asking many questions as I build this.
Old 05-05-2026, 01:09 PM   #3
California Travieso
Send a message via Yahoo to California Travieso
First thing to do is get rid of the V8 and go back to a four banger.
David Serrano
California Travieso is online now   Reply With Quote
Old 05-05-2026, 01:33 PM   #4
Mike1291
Mike1291's Avatar
Everyone has their opinions. But putting in a V8-60 is not an opinion - it's an incorrect choice
Honestly a V8 Model A is not the worst mod in the world. I've heard many stories from older club members about doing that very thing in the 50s and 60s when someone wanted a cheap upgrade. Just that the Model A Fordbarn may not be the best platform for figuring out your build.
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 05-05-2026, 02:36 PM   #5
Bob C
Where did the original post mention a 60HP?
Old 05-05-2026, 03:01 PM   #6
37 Coupe
37 Coupe's Avatar
The Fenton cast iron headers are probably worth $200 or more especially if they are the original ones from the fifties that fit better.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 05-05-2026, 04:08 PM   #7
nkaminar
nkaminar's Avatar
I am not a V8 man so I am going to ask a stupid question. What model V8 is it?
Old 05-05-2026, 04:14 PM   #8
Mike1291
Mike1291's Avatar
It did not, just conjecture for a quip.
There are a few versions of the flathead and it would be nice to know which one this is.
From the number of studs on the cylinder head this appears to be a "24 stud" motor from 1938 or later.
Old 05-05-2026, 04:30 PM   #9
nkaminar
nkaminar's Avatar
V8 Model A's were the rage in the 1950's. This could be a nostalgia car. Candy apple red with orange and yellow flames and a multi carburetor manifold with lake pipes. Cool. Bitchen.
Old 05-05-2026, 04:50 PM   #10
old ugly
old ugly's Avatar
pre 1948
good score for $200. the headers and the tranny are worth that.
engine is gonna cost north of $7000 to get it hotrod ready. IF the block is good.
flathead v8 is not a poor mans sport anymore, but i guess nothing really is.
should be a fun project.
ps. look closely at the valve seat areas for cracks and then also have it magnifluxed before you start
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 05-05-2026, 05:21 PM   #11
J Franklin
J Franklin's Avatar
Originally Posted by old ugly View Post
pre 1948
If that one doesn't work out I have access to a fully rebuilt '34 flathead long block with most all components. Dist, starter, fuel pump water pumps, wiring looms/with new wire. manifolds, rebuilt oil pump, 94 carb, and maybe a few things I forgot. $3450.
Old 05-05-2026, 05:53 PM   #12
ModelA29
ModelA29's Avatar
Unfortunately there is little tolerance for "improved" Model As among the faithful. Check out the HAMB forum https://www.jalopyjournal.com/forum/...ssage-board.5/ You'll be welcomed with open arms.
ModelA29 is offline   Reply With Quote
Old 05-05-2026, 06:27 PM   #13
Joe K
Joe K's Avatar
And get Charlie Yapp's "Trial Package" and give it a look over. Charlie VERY RARELY goes to the V8, and the magazine has some amazing mods to Model A and Model T.
The trial package is VERY reasonably priced - four "past" magazines of his choice. He'll do it ONCE for any buyer.
I did the package before signing up for a year subscription. The earliest Secret of Speed in the package was like 2017.
https://www.secretsofspeed.com
Joe K
Shudda kept the horse.
Joe K is online now   Reply With Quote
Old 05-05-2026, 07:22 PM   #14
big deuce
big deuce's Avatar
David Serrano
What for??
big deuce is offline   Reply With Quote
Old 05-06-2026, 11:11 AM   #15
ronn
What for??
wrong site for hot rods..................
Old 05-06-2026, 11:49 AM   #16
ModelA29
ModelA29's Avatar
Originally Posted by ronn View Post
What for??
Even the 4 cylinder ones?
Old 05-06-2026, 11:57 AM   #17
ronn
this is basically a purist site. interested in hot rods- as suggested- go to the HAMB
Old 05-06-2026, 12:38 PM   #18
J Franklin
J Franklin's Avatar
https://forums.aaca.org/topic/455801...omment-2980245
Old 05-06-2026, 12:41 PM   #19
rotorwrench
rotorwrench's Avatar
A lot of mods go into a model A frame to use it for an AV8. The motor looks to be a post war 59 series but a person needs to see the big "59" on the rear clutch/flywheel area or half bell if you will, but that's not a guarantee of it being a 239 engine. Ford made 221 blocks that had the big 59. The frontal characteristics will tell as in the pencil test.
The 59 block is a good one for AV8 conversions since it's already set up to be the shortest possible from front to rear. Model As don't have a lot of room down front.
Many a person has purchased a flathead V8 engine only to find it cracked in the valve pockets from overheating or cracked due to freeze up of the coolant in the water jackets. It's a fair amount of work to tear one down unless you have the usual trouble saving tools for valve removal. Brake a leg on that one and hope for the best.
Old 05-06-2026, 02:08 PM   #20
47topless
47topless's Avatar
Very cool project. Building a period correct Model A hotrod was always a dream of mine. Old flathead engines and Model A bodies were made for each other. Like Peanut butter and chocolate.
Good luck with your build.
47topless is offline   Reply With Quote
